Hi there,
I hope ya'll are doing well. I am formulating a non-linear regression model and I'm getting an error when I try to estimate parameters. I've started using EViews only recently and so maybe I'm missing something basic.
Following is a sample of the model I'm trying to estimate -
y = c(1) + c(2)*log(1+x1) + c(3)*log(1+x2 + c(4)*x3) + [ar = c(5)]
If try to estimate the c(i), I keep getting an error message that says "Log of non positive number" I suspect it is because c(4) turns out to be negative in the estimation process. Is there a way I can constrain a variable to ensure that it remains positive?
If you have any other thoughts on the source of the error message, please let me know.
Thanks,
~D
Constraining estimation results
Re: Constraining estimation results
Please see the following post:
http://forums.eviews.com/viewtopic.php?f=4&t=48
Thank you for your reply. I had used couple of transformations but it yielded in different errors
Squared transformation of the variable -
y = c(1) + c(2)*log(1+x1) + c(3)*log(1+x2 + c(4)^2*x3) + [ar = c(5)] ---> yields an error "overflow"
Exponential transformation of the variable -
y = c(1) + c(2)*log(1+x1) + c(3)*log(1+x2 + exp(c(4))*x3) + [ar = c(5)] ---> yields an error "singular matrix"
Do you think it is perhaps because the function has too many parameters to estimate?
~D
~D
Just sounds like your function is so non-linear that EViews is having trouble finding a solution. You could try changing the starting values (i.e. the values in your C vector) to see if it helps.
