Zivot-Andrews Unit Root Test
Re: Zivot-Andrews Unit Root Test
Thanks for the code trubador. I've got a pretty low level question. How do you tell eviews to run program mode A B or C, what do you have to type in the program arguments box?
Cheers
Cheers
I have the same question. This code gives the result for model C. How do we get the result for model A.
The code makes it pretty clear - you enter the model you want as the second argument.
thank you very much. I could not notice that argument. best regards
I've been testing the zauroot code against a large range of timeseries. All of them indicate a break in the trend and intercept. Does anyone have an example file where there is no break (or a simulation process)? Or am I misunderstanding something at a more basic level? Thanks
malikbensafta
Hello
Could some one help me about zivot andrews
when executing, an error message ..No Upper define !
What matter?
What matter?
Hurlstrino
I get the following error.
"Is not defined or is an illegal command in "EQUATION TEMP.LS DY (Y-1) C @ TREND DY(-1 TO -4)".
Any ideas ?
I am running Eviews 7.
Any ideas ?
Hurlstrino
Any ideas ?
Ok, I ran the routine for the older versions of Eviews to see what happens , and now I get an error saying
"Insufficient number of observations in "EQUATION TEMPL.LS Y(-1) C @TREND (@TREND>17-2) (@TREND>17-2)*(@TREND-17+2 DY(-1 TO -3)"
I do not think it is a version related issue.
You cannot put a space between @ and TREND. Moreover, (Y-1) should be replaced with Y(-1). Please do not change any of the structural parts of the subroutine."Is not defined or is an illegal command in "EQUATION TEMP.LS DY (Y-1) C @ TREND DY(-1 TO -4)"
Here, the message is clear: You do not have enough observations to carry out the routine. You can lower the value of trimming parameter or better yet, increase the number of observations."Insufficient number of observations in "EQUATION TEMPL.LS Y(-1) C @TREND (@TREND>17-2) (@TREND>17-2)*(@TREND-17+2 DY(-1 TO -3)"
Hurlstrino
If I reduce the trimming, I get a singular matrix.
Do you have any other suggestions please, or would you mind taking a look at my data for me ?
maragloria
I've posted this question on the Econometric Discussions forum but I am not sure it belongs there so I am posting it again here. It is about interpreting the results of Zivot-Andrews Unit Root Test.
I ran the routine "Zivot-Andrews Unit Root Test" to perform a unit root test with trend break and I would like to know how to interpret the results.
From the equation “ZA” I get the following results:
Dependent Variable: DY
Method: Least Squares
Date: 01/04/11 Time: 16:42
Sample (adjusted): 1982Q2 2010Q1
Included observations: 112 after adjustments
Variable Coefficient std. Error t-Statistic Prob.
E_POP_RT(-1) -0.006628 0.001692 -3.916339 0.0002
C 0.062132 0.015577 3.988797 0.0001
@TREND 0.000272 8.29E-05 3.281443 0.0014
DU 0.001541 0.000606 2.541795 0.0125
DT -5.38E-05 3.49E-05 -1.541206 0.1263
DY(-1) 1.995009 0.088271 22.60086 0.0000
DY(-2) -1.078224 0.208280 -5.176808 0.0000
DY(-3) -0.295512 0.208189 -1.419440 0.1588
DY(-4) 0.391776 0.089783 4.363594 0.0000
How do I test for the unit root? Should I test whether or not the coefficient of e_pop_rt(-1) is equal to 1?
Thanks,
Mara
call zivot(y,"C",4)From the equation “ZA” I get the following results:
Thanks,
Mara
maragloria
I just realized you're running the regression using the 1st difference of the series Y. So in this case, to interpret the results I just use the t-stat of the coefficient Y(-1) to test for the null that this coefficient is equal to zero (using the critical values posted previously). Is this correct?
I was confusing your test with the one from Vogelsang and Perron (1998).
Thanks,
Mara
Thanks,
Mara
raquelopez
Thank for such useful tool! I have a question. Could I use the bic criteria instead of the aic one by replacing "min_aic" by "min_bic" in the subroutine?
Thank you,
Raquel
Thank you,
Raquel
No, you have to change more than that. You need to make following modifications to relevant parts of the code:Could I use the bic criteria instead of the aic one by replacing "min_aic" by "min_bic" in the subroutine?
!min_bic = !bic0
for !lag=maxlag to 1 step -1
equation temp.ls dy y(-1) c @trend dy(-1 to -!lag)
!aic = log(temp.@ssr/!nobs)+2*(temp.@ncoef/!nobs)
!bic = log(temp.@ssr/!nobs)+log(!nobs)*(temp.@ncoef/!nobs)
if !bic < !min_bic then
!min_bic = !bic
!best_lag = !lag
else if !min_bic = !bic0 then
!best_lag =0
endif
endif
I'm getting the message: "y is not defined in "call zivot(y,"C",4)"
Please, what can I do?
Vanessa
Vanessa
Return to “Program Repository”
