I'm trying to build a graph (XY line) from a matrix of about 1000 columns, cause I'd like to show in a single graph all the repetitions (yield curves) generated by a stochastic simulation.
I think Eviews plots only the first 300 columns if I choose the graph type "XY line" and I select "Single graph - First vs. All" in the Multiple series combo.
I know that there's a limit for the legend entries, I wonder if there's a limit also for the numbers of lines showed.
I'm using Eviews 7.1.
Thank you very much.
XY line graph limit
EViews Pamela
Re: XY line graph limit
Yes, you are correct. EViews limits the number of lines to 300.
