Removing NA values from a series in the workfile
mectricsdonk
Dear dear econometric fanatics :series:
{using Eviews 6}
I was wondering how I could remove the NA values (at irregular and regular dates; bank holidays + weekends) from my financial time series, as I'm not able to estimate a garch model with a discontinuous series.
I went through the help file, saying that I should leave those days out. It unfortunately didn't tell me how to do so in eviews.
kind regards :eviews6:
{using Eviews 6}
Re: Removing NA values from a series in the workfile
Proc->Contract Current Page
then set the sample to "if X<>NA" where X is the series with the NAs.
mectricsdonk
Thank you very much
hello guys! i have a problem.
i want to count how many times some values from the rows of a matrix are over a threshold that i set (its standard deviation). the problem is that i have na values in the matrix and so eviews5 gives me this error message "NA found in matrix in IF VK>VKK then"
the program is:
smpl @all
series yt
group g1
'for !j=1 to 189
'g1.add dser{!j}_sa
'next
sample s0 1989m2 2010m10
stomna(ainflsa,m_ainflsa,s0)
vector(261) v_stdev
for !i=1 to 261
vector v{!i}=@rowextract(m_ainflsa, !i)
v_stdev(!i)=@stdev( @transpose(v{!i}) )
mtos(v_stdev,s_stdev,s0)
'delete m_ainflsa v_stdev
smpl @all
series yt=0
for !j=1 to 261
smpl @first+!j @first+!j
!k=0
for !i=1 to 189
vector(1) vk=@abs(m_ainflsa(!j,!i))
vector(1) vkk=v_stdev(!j)
if vk>vkk then
!k=!k+1
endif
yt=!k
can you help me?how can i omit the na values from this process?
the program is:
smpl @all
series yt
group g1
'for !j=1 to 189
'g1.add dser{!j}_sa
'next
vector(261) v_stdev
for !i=1 to 261
smpl @all
series yt=0
for !j=1 to 261
!k=0
for !i=1 to 189
if vk>vkk then
!k=!k+1
endif
yt=!k
Check whether the values are NAs first :D
yes they are..and NAs are a lot.
I think you misunderstood my statement.
Currently you have:
I'm saying you should do this:
Currently you have:
if vk > vkk then
if vk<>na and vkk<>na then
if vk > vkk then
thanks a lot my friend!!indeed i misunderstood your statement before... i ll test the command you gave me today and i ll report back!! :D
How does one remove NAs in a data series in Eviews 7.2?
Could you define what you mean by that?
Do you want to remove them from the workfile? From the sample? Or map them into different values?
I want to remove the NAs in the series I imported from Excel. Can I create a new series that excludes the NAs? How is this done in Eviews 7.2?
You can always avoid using observations with NA in them by letting EViews handle them, or if necessary, setting a sample condition. Generally, you shouldn't need to "remove" observations permanently. If I'm understanding correctly, that is what you want to do. In that case, you can do a workfile extract.
From the workfile window, Proc/Copy Extract from Current Page (you can answer the resulting prompt by choosing to do either by link or value), and specify the condtion that your series isn't NA as in
which will remove all observations where Y=NA. Note that this will shorten ALL of the series copied or linked into the new page. You can't have series of unequal lengths in a workfile.
@all if y<>naRe: Removing NA values from a series in the workfile
series y =@recode(x=na,2.71828,x)
It is suggested to use condition @all if y<>na to avoid obs with NA. I have 50 series to be contracted that way. Is it possible to do all at once by condition or by programming.
Thank you.
Thank you.
