Alpha series instead of regular series problem
mectricsdonk
Postby mectricsdonk » Sat Oct 16, 2010 1:05 pm
Dear Eviews fanatics!
I'm currently working on my dissertation about Realized GARCH models (a, relatively new (Hansen, Huang, Shek 2010), extension of the GARCH model).
This model uses "realized measures" (i.e. high frequency data). I've got an .csv file with data from a lot of different indexes, running from 1996 to 2009,
for example dow jones returns, nikkei returns, etc. After opening the file with eviews (6), some series are labeled as an alpha
series, while others are normal. I've noticed that for the alpha series, a lot of data is missing and have values NaN (not a number).
As high frequency data wasn't available until, for example, 1999 in the netherlands. Any suggestions how I could change it into a regular series?
I've tried exchanging th NaN values for zero's, but no succes.
Greets from amsterdam!
Postby EViews Gareth » Sat Oct 16, 2010 1:41 pm
Posting your csv file is probably a good idea.
mectricsdonk
Re: Alpha series instead of regular series problem
Postby mectricsdonk » Sat Oct 16, 2010 1:46 pm
of course, my bad..
the file is too large to upload (+-4mb>2mb allowed)
the file can be found on
http://realized.oxford-man.ox.ac.uk/data/download
thanks!
Postby startz » Sat Oct 16, 2010 2:06 pm
EViews has a couple of different methods of reading files. Try dragging-and-dropping the file onto EViews. When I did that everything came in as numerics with NAs in the right places.
mectricsdonk
Postby mectricsdonk » Sat Oct 16, 2010 2:37 pm
Thanks! But unfortunately it doesn't work.
FALSE:=I cut off the first 3 years of the data set and saved it in an excel file. After that I could import it in eviews and no more the alpha series!
(of course I miss 3 valuable years of indices that did have high frequency data at the time)
It seems eviews labels series as an alpha one if a certain amount of consecutive points in time have letters in them.
Well I'll keep on looking for the solution :eviews6:
*edit: still alpha series after removing first three years, don't know what I was thinking, probably som false-saturday-night-excitement going on in my brain :series: *
Postby startz » Sat Oct 16, 2010 2:46 pm
See if the attached file helps.
realized.library.0.1.zip
(1.06 MiB) Downloaded 367 times
mectricsdonk
Postby mectricsdonk » Sat Oct 16, 2010 2:54 pm
Wow impressive! Thanks a lot! :D
Do you perhaps care to ellaborate for a bit? It's always nice to have some extra data manipulation tricks up in the sleeve.
Again thanks
Postby startz » Sat Oct 16, 2010 3:08 pm
To be quite honest, I just dragged the csv file onto EViews.
If you're not using 7.1, there's a chance something has improved...
mectricsdonk
Postby mectricsdonk » Sat Oct 16, 2010 3:10 pm
enough said lol!
cheers!
