I'm trying to assign +1 values to a 'trade' series when my 'res' (=residual) series is greater than standard deviation (=s) and -1 when my 'res' series less than negative standard deviation
if res>s then
series trade=1
else
if res<-s then
series trade=-1
endif
endif
but getting a message "NA found in matrix IF RES>S then"
Is there a way to avoid the NA message?
NA in "if" statement
tchaithonov
Re: NA in "if" statement
use @recode instead.
@recode will work for the first time, but when I use it for the second, it will overwrite the first results.
Any other suggestions?
series trade = @recode(res>s, 1, 0)
series trade = @recode(res<-s,-1,trade)
Thank you for the help
