Hello everybody.
I am using Eviews 7. Based on a model a generated results, which are stored in 12 vectors (250 lines). These vectors are summarized in the matrix "S_Summary", where each column refers to one vector. Then I am generating histograms for each column based on:
S_Summary.distplot(hist)
My question: How can I limit the x axis to -1 and 1 and the y-axis to 0 and 60 for all 12 histograms? It seems to be that the command "axis" is only working with time series.
Thank you very much and best regards.
Herman
Graphic output for matrix
