I have a file imptest.txt which looks like:
testimport
NA
1
2
3
4
NA
5
6
7
Then in EViews I enter:
import(type=text,resize) imptest.txt @freq monthly 1960m1
This creates a variable testimportna!
What am I doing wrong?
Tim
import with NA as first obs
Re: import with NA as first obs
try:
import(type=text,resize) imptest.txt colhead=1 @freq monthly 1960m1
Thanks Gareth! Works great!
Tim
Tim
Hi Gareth,
The import command has worked great for most cases, but now I have a problem I can't figure out.
My data is only one observation and some of the values may be NA's.
gdp rff rtb rg10e
5 4 NA 3
The import command will make gdp, rff and rg10e numeric series and rtb will be a alpha series.
I want rtb to be a numeric series with the missing value, NA, as its only observation.
The import command I use: import(type=text,resize,mode=u) smallfile.txt colhead=1 @freq 4 2010q1
This type of command has worked for every other case I've tried to import.
Tim
gdp rff rtb rg10e
5 4 NA 3
Tim
OK, I think I figured it out.
On the import command I need to add a "format=<n>F" where <n> is the number of series I am reading. That forces the import to read all the values as numeric series as opposed to alpha series.
Is there a way to use a meta character like "*" to say format=(*F) and have all values series read in as numeric?
An observation: The documentation for format is way over in the wfopen documentation. I had no idea the format option was available for the import command. Some better cross referencing would be nice.
Tim
Tim
There is no way to specify all series.
I tend to agree on the documentation issue. Although wfopen, open, import, pageload, and to some extent, wfsave, save, pagesave all have almost identical options, and it was felt somewhat excessive to repeat those options in multiple pages, hence the the references to wfopen.
