Menu and batch
Posted: Thu Jun 18, 2009 3:16 pm
by salima
Is there a way to obtain the corresponding commands while using the menus as it is possible in Excel, Stata or Sas Guide?
And is there a way to run a batch program just usung a script that run it every day at the same time. it is for financial applications
salima
Re: Menu and batch
Posted: Thu Jun 18, 2009 3:26 pm
Some menu items will let you see the equivalent command line form. Most estimations, for example, will show the command line form in the Representations View. Some procs that create new objects will put the command line form into the History label of the created object. But in general there is no "macro record" like function.
It is relatively easy to set up Windows task scheduler to run EViews at a certain time each day.
