More graph programming questions
barteph
Postby barteph » Wed Apr 02, 2014 4:05 am
How do I program so that the series in a line graph are renamed?
For instance, if I have F_VA, G_VA and I want these to show up in ledgend as "France Value Added" and "Germany Value Added"
How would I program a graph with 2 axes, where one of the axes is inverted?
say for instance, I have F_CAPEX and EU_UNCERTAINTY, France Capex and the EU uncertainty index. I want the EU uncertainty index to show up on an axes that is inverted.
Many thanks
Re: More graph programming questions
Postby EViews Jason » Wed Apr 02, 2014 10:13 am
Use:
mygraph.name(1) France Value Added mygraph.name(2) Germany Value Added
To answer the second part, you will have to put the second series on the right axis and then invert it
mygraph.setelem(2) axis(r) mygraph.axis(right) invert
barteph
Postby barteph » Thu Apr 03, 2014 4:52 am
Thanks so much Jason!
How would I program it to give the graph a name say "Value-Added Investment" ?
Finally if I have number of countries for the series how would I do this as a loop
Other then
show VA_France.Line
show VA_Germany.LIne
show VA_Spain.Line
show VA_Greece.Line
and then the freeze command with each of them.
etc
Postby EViews Jason » Thu Apr 03, 2014 8:42 am
mygraph.text(t) Value-Added Investment
Other then
show VA_France.Line
show VA_Spain.Line
show VA_Greece.Line
etc
for %s VA_France VA_Germany freeze({%s}_graph) {%s}.line next
barteph
Postby barteph » Thu Apr 03, 2014 3:32 pm
Sorry I meant to ask how you would loop the renaming of a series in a graph. So I have VA_graph.line.
How would I loop it so that I can rename all the series in the graph?
VA_graph.name(1) France
VA_graph.name(2) Germany
VA_graph.name(3) Italy
VA_graph.name(4) Spain
VA_graph.name(5) Euro Area
VA_graph.name(6) UK
I would also like to add % to the y axis title. How do I program so that axes are labeled.
barteph
Postby barteph » Thu Apr 03, 2014 5:50 pm
With regards to above.
What if I wanted the right inverted axis to start at a certain value?
Postby EViews Gareth » Thu Apr 03, 2014 7:38 pm
All of these commands are listed in the graph section of the Object Reference pdf
barteph
Postby barteph » Fri Apr 04, 2014 7:00 am
where is this pdf or can you send a copy?
Postby EViews Gareth » Fri Apr 04, 2014 7:15 am
Help menu
barteph
Postby barteph » Fri Apr 04, 2014 8:05 am
I don't see what I want to do in here...can you direct me to page(s)
I can't get setobslabel command to work or label y axis.
Postby EViews Gareth » Fri Apr 04, 2014 8:43 am
VA_graph.name(6) UK
%names = "France Germany Italy Spain ""Euro Area"" UK" for !i=1 to 6 va_graph.name(!i) @word(%names, !i) next
Postby EViews Gareth » Fri Apr 04, 2014 8:45 am
You want the
graph.axis range
and
graph.axis format
commands, I think.
barteph
Postby barteph » Fri Apr 04, 2014 11:09 am
Hmm... the loop above doesn't seem to work for me.
Postby EViews Gareth » Fri Apr 04, 2014 11:20 am
%name = @word(%names, !i) va_graph.name(!i) {%name}
barteph
Postby barteph » Fri Apr 04, 2014 12:41 pm
when I use this I just get for each series
@word("France Germany Italy Spain ""Euro Area"" UK", 1)
@word("France Germany Italy Spain ""Euro Area"" UK", 2)
@word("France Germany Italy Spain ""Euro Area"" UK", 3)
@word("France Germany Italy Spain ""Euro Area"" UK", 4)
@word("France Germany Italy Spain ""Euro Area"" UK", 5)
@word("France Germany Italy Spain ""Euro Area"" UK", 6)
