delete observations
anl
delete observations
Postby anl » Wed Jun 17, 2009 2:39 am
Hi!!
I have a dataset that I have devided into 66 different workfiles. Each workfile consisting of several observation each day during one year, I have made some new columns by using "generate series by equation". Unfortunately I have now found out that this is biased and I need to delete the first observation each day. I dont know how to do this(without deleting one by one, which would take a week), can you help me with this? In addition, the new columns need to be updated..
anl
Casper
Re: delete observations
Postby Casper » Fri Oct 16, 2009 1:39 am
Hi. I see that the question was posted some time ago, but I recently run into the same difficulty and thought I could post one method to solve it here in case other people are struggling with the same.
1. Create a sample containing only the observations you want to keep. If you want to combine criteria, the if NOT method is useful. Let's say you've created a series, first_obs_that_day, which identifies the first observations each day. However, you only want to delete those observations before 2008.
sample mysample if NOT (criteria for deletion, e.g. first_obs_that_day=1 and year<2008)
2. Copy the sample to a new page and (optionally) delete the old one
pagecopy(smpl=mysample, page="NewPage")
pageselect NewPage
pagedelete OldPage
delete mysample
In your case, you might need to loop this routine for all your workfiles, but that should be easy to automate.
Casper.
Santosh
Postby Santosh » Wed Oct 12, 2016 12:33 am
I want my sample to constitute like this: 1970 2012. However, i want to drop, say, 1975 to 1977, and 1991.
How to specify the sample.
Can anyone plz help?
Thank you.
Postby startz » Wed Oct 12, 2016 5:54 am
smpl 1970 1974 1978 1990 1992 2012
Santosh
Postby Santosh » Wed Oct 12, 2016 10:21 am
Thank you
Santosh
Postby Santosh » Mon Oct 17, 2016 2:01 pm
I have monthly data for series X. I want to convert X in to quarterly data.
Can anyone please suggest how to generate this?
Thank you in advance.
Postby EViews Gareth » Mon Oct 17, 2016 2:02 pm
