Easy Query
Tatha
Easy Query
Postby Tatha » Wed Jun 10, 2009 4:33 am
For the first time, I'm trying to add description/labels to data in my database (earlier, I maintained a list of series names elsewhere). I took just 2 series as test series: CZ_OECD_CLI and HU_OECD_CLI which are stored in a database called 'emea'. Used the following commands:
CZ_OECD_CLI.label(r) OECD leading economic indicator for CZ, trend-restored
CZ_OECD_CLI.displayname OECD leading economic indicator for CZ
CZ_OECD_CLI.label(s) OECD
HU_OECD_CLI.label(r) OECD leading economic indicator for Hungary, trend-restored
HU_OECD_CLI.displayname OECD leading economic indicator for Hungary
HU_OECD_CLI.label(s) OECD
After overwriting the old series in the database, I can see these series and they say ,[displayname] OECD leading economic indicator for CZ
and all that. Easyquery when name is matched to *oecd* finds these series, but an easyquery with Description matching *OECD* turns up nothing. My aim is to add longer descriptions to all my series in the form of labels and display names and search for them that way. What am I doing wrong?
Thanks in advance,
Tatha
Re: Easy Query
Postby EViews Gareth » Wed Jun 10, 2009 8:02 am
You need to use label(d) to set the description.
Tatha
Re: Easy Query
Postby Tatha » Wed Jun 10, 2009 8:52 am
Worked like a charm :) Many thanks Gareth.
ecardamone
Re: Easy Query
Postby ecardamone » Mon Sep 22, 2014 7:20 am
Is there a better way to document a series than what I have below? For example, is there a way to do this in a single line without repeating USGOD_ND? Thanks for help!
USGOD_ND(C)
USGOD_ND(D) United States, Gross Output, Manufacturing
USGOD_ND(S) BEA
USGOD_ND(U) Millions of US Dollars
USGOD_ND(R) History edge: 2013
USGOD_ND(R) Primary data: 1997-2012
USGOD_ND(R) Supplement:
USGOD_ND(R) NAICS 31-33, 511, 512
USGOD_ND(R) Note: Pre-1997 data backcasted using NAICS 2002 data growth profile
USGOD_ND(R) Note: Data extended using proxy WIS IP 2013
USGOD_ND(R) Note: Data extended using growth pattern of WIS IP 2013 United States
