Changing links in the Eviews Excel add-in
Posted: Mon Feb 10, 2014 2:53 pm
by fajdelb
Hi there,
I'm using the Excel add-in for Eviews to export data from my Eviews databases to Excel spreadsheets. It's a really convenient way to update the data in the spreadsheets when the databases change.
I'd like to move the location of my databases in my directory, but when I do that I discover that the add-in is still linking to the old location. I've tried to use the 'Manage' function in the Excel add-in to change the link location, but with no luck.
I'm really not keen to rebuild very large linked Excel workbooks! Is there a way around this?
Felix
Re: Changing links in the Eviews Excel add-in
Posted: Mon Feb 10, 2014 3:22 pm
by EViews Steve
Hi Felix:
Each time you import data using the EViews Add In for Excel, all it is doing is creating a standard link to an OLEDB datasource. You can edit these datasource links using the Excel interface. For example, in my Excel 2010, I click on the "Data" ribbon, then "Connections". This will show my a list of all the available database connections on my current spreadsheet. I select one of them and click "Properties". I then click on the "Definition" tab to see the connection string. The string looks like this:
Provider=EViewsOleDbProvider.EViewsProv.1;Initial Catalog=Untitled;Path=C:\files\alpha.wf1;Max Rows=1000000;Timeout=10000;Include ID Series=False;Type=Auto;Server="";Username="";Password="";Max Objects=0;Object Types=series;Hold License=True
You can manually edit the "Path" section to point to the new location of your workfile.
Posted: Mon Feb 10, 2014 4:14 pm
by fajdelb
Excellent, that's solved my problem! Thank you
