Detecting equation format & sorting correlations
Posted: Sun Jun 07, 2009 4:38 pm
by tchaithonov
Hi everyone,
I have 2 questions when writing a small program in eviews. Firstly, is it possible for eviews to identify the format ( d( ), dlog(), log(), etc) of the dependent variable in a group after it creates the group by eq_xyz.makeregs group1? e.g.,
1st procedure:
equation eq_xyz.ls(n) <some transformation of y> c {x variables}
2nd procedure:
eq_xyz.makeregs group1 scalar varnum = eq_xyz.@count table tab for !i = 1 to varnum ' everything tab(!i,1) = eq_xyz.@seriesname(!i) next !i
(it's all algorithm beyond this point)
- 1st var in tab --> dep var
- check dep var's transformation
- if it's format a, do 1; format b, do 2, ...
Second question relates to sorting. I know there has been some discussions about sorting for a while, but I don't see if there is a way to sort results from correlation. Say, this is what I got so far:
group gp_1 a b c d e freeze(table) gp_1.cor
if I am interested only in the correlation between variable a and the others (a & b, a & c, etc), and want to sort from highest to lowest their correlations, what should I do?
Thanks guys!
Re: Detecting equation format & sorting correlations
Posted: Sun Jun 07, 2009 11:46 pm
by trubador
Regarding to your first question:
if group1.seriesname(1) = "D(Y)" then ... else if group1.seriesname(1) = "DLOG(Y)" then ... else if group1.seriesname(1) = "LOG(Y)" then ... ... endif endif endif 'Please note that strings are case sensitive so you should write them in capitals
Regarding to your second question:
vector(3) correl !k=1 for %i a for %j b c d correl(!k)=@cor({%i},{%j}) !k=!k+1 next next vector correl_sort=@sort(correl,"d") 'You should decide how to handle negative and positive correlations
Posted: Mon Jun 08, 2009 7:41 am
by tchaithonov
Thanks a lot, trubador! You've saved me a lot of time!
