For the life of me I can't get an addin to show the same error handling that is displayed when the code is being run as a program. I have tried using the addin/-addin code but whatever I do the addin suprreses the errors. in particular i'm trying to handle errors relating to sharing violations when importing data using "import(type=excelxml, c=max)" method.
Any help appreciated, I can send the addin if needs be
thanks
jack
displaying errors for addins
Re: displaying errors for addins
Post the Addin.
see attached with work file showing the table it uses for reference. the addin works but if for example the file name is mis-spelt it won't say anything as to why it fails. When ran as a program it prompts with message box/log. i've ended up using the status line but still interested to know the issue.
thanks!
Jack
thanks!
Jack
- data import.prg
- (1.72 KiB) Downloaded 317 times
- WF1.WF1
- (61.08 KiB) Downloaded 265 times
Seems to work for me - I get the same errors whether I run the program as a program or as an Add-in.
not sure what the issue is then as when ran as an addin it's definitely not been showing the same errors.
The addin is distributed via an azip file installer but i couldn't post that. would that make a difference?
Shouldn't
