Recursive Forecast with loop
Posted: Sat Dec 14, 2013 11:50 am
I have another issue. I tried to adjust the program for recursive window estimation that was (almost) like that provided somewhere in this forum. I wanted to create 12 X variables and than to regresses Y on a constant and each X in separate equations. For the simple IS analysis the procedure works. But when I try to adjust it for the OOS analyis I get an error message: "X13 is not defined in Freeze/ls_vol_x3013) eq_oos13.ls y z1 x13"
Of course its not defined, as I did not create it by purpose but also did not use it. And the only equation that is added to my workfile is ey_oos13 which is empty. I don't get where I made the mistake and would be very thankful if somebody could have a look!
Thank you!
smpl @all
'create a y series
series y=std_ann_vol_m
series z1=std_ann_vol_m(-1)
'create 15 X series
for !l=1 to 12
series x1=std_dividend_yield(-1)
series x2=std_exr
series x3=std_exr_gr
series x4=std_inf_gr
series x5=std_ms1_pp
series x6=std_ms1_sppy
series x7=std_ms3_pp
series x8=std_ms3_sppy
series x9=std_ppi_gr
series x10=std_term_spread
series x11=std_unempl
series x12=std_vol_inf
'run rolling regression
' set window size
!window = 180
' set step size
!step = 1
' get size of workfile
!length = @obsrange
' declare equation for estimation
equation eq_oos{!l}
'calculate number of rolls
!nrolls = @floor((!length-!window)/!step)
'matrix to store coefficient estimates
matrix(4,!nrolls) coefmat ' where 2 is the number of coefficients
'series to store forecast estimates
series fcast2
'redundant series for catching start and end points
%start = "@first" '@otod(@ifirst(ser))
%end = "@last" '@otod(@ilast(ser))
'variable keeping track of how many rolls we've done
!j=0
' move sample !step obs at a time
!j=!j+1
' set sample for estimation period - recursive window
%first = @otod(@dtoo(%start))
%last = @otod(@dtoo(%start)+!i+!window-2)
smpl {%first} {%last}
' estimate equation - where the equation is y=c(1) + c(2)*x1
freeze(ls_vol_x30{!l}) eq_oos{!l}.ls y z1 x{!l}
' store coefficients
colplace(coefmat,eq_oos{!l}.@coef,!j)
' 1-period-ahead forecast
%1pers = @otod(@dtoo(%start)+!i+!window-1) 'start point
%1pere = @otod(@dtoo(%start)+!i+!window) 'end point
if @dtoo(%end) < @dtoo(%1pere) then 'check whether the forecast end point is greater than the workfile end point
exitloop
endif
' set smpl for forecasting period
smpl {%1pers} {%1pere}
' forecast with command *forecast* (see also *fit*)
eq_oos{!l}.forecast(f=na) yf{!l}
' set sampl to obtain the 4th period observation
smpl {%1pere} {%1pere}
' store forecasts
fcast2{!l} = yf{!l}
'smpl @all
'show coefmat
'show fcast2.line
'd(noerr) yf
Thank you!
smpl @all
'create a y series
'create 15 X series
for !l=1 to 12
series x2=std_exr
' set window size
!window = 180
' set step size
!step = 1
!length = @obsrange
equation eq_oos{!l}
series fcast2
!j=0
!j=!j+1
exitloop
endif
' store forecasts
fcast2{!l} = yf{!l}
'smpl @all
'show coefmat
'show fcast2.line
'd(noerr) yf
