Command for number of iteration
Posted: Mon Nov 18, 2013 8:11 am
I am doing a simulation exercise using GARCH models. I have simulated data and now I want to estimate the same model with the simulated data. I have noticed that for some models the estimation results do not make much sense. I have two issues:
1. "Failure to improve likelihood after 1 iteration" => standard errors are not calculated
2. Convergence is not achieved after 500 iteration (when I set the maximum number of iteration higher it still not converge)
Are there a set of commands that could be used to delete these models?
I have some ideas:
Regards to issue number 1, I could check if the standard errors are "NA" for a specific model and then delete the model. Is this a good way to do this?
For the second issue, I could check if the number of iteration is equal to the maximum I have set.. But what is the command to get the number of iteration? Or do you know of any better solution?
Cheers
Steven
I have some ideas:
Cheers
Steven
