I use the command "makegroup" to make tables. My data er quarterly, and I want the tables to show annual avarages. I haven't found the commands that makes this possible. Using menus, I use
"tableOptions",
Column grouping frequency first: annual, second: annual, Data display "the first 1 ..."
The result is a table that shows variables in the first column and years in the first row.
Does anybody know the commands that produce this result?
Commands for adjusting tables
Re: Commands for adjusting tables
You want the group.ddtabopts and group.ddrowops commands. Both are documented in the group section of the Object Reference.
