Can someone please help me with the following code:
On the following data set:
I want to run a lower triangular TV-BEKK model on the attached data file, but it keeps failing.
Is my coding correct or did I make an error?
Please advise. Thank you! Nic
Lower triangular Trivariate BEKK GARCH model
Re: Lower triangular Trivariate BEKK GARCH model
Check your determinant specification (i.e. deth), which has to be positive. It seems to be the source of the problem.
The deth is correctly specified from theory - but it seems that the covariance factors (cov_y1y2, etc) and the variance factors converge after a few periods - probably causing the deth to show NA.
Do you have any idea why the var and cov factors converge to a number?
thanks! ~N
thanks! ~N
Ah wait I think you're right- specifying the deth as vary1*vary2*vary3 shows some results - and it seems that the converged cov and var variables were as a result of the NA deth...
But doing so the results are somewhat suspect.. could this be as a result of the invh specifications for a lower triangular bekk model that changed? How would you specify the invh elements now?
Thanks!
N
Thanks!
N
- Tv-garch_lowertriangle 5 - C uppertriangle edited.docx
- (24.18 KiB) Downloaded 708 times
four-variate BEKK GARCH model
Dear trubador,
I have tried four variate garch. But I am not able to get output. Pls let me know where I am wrong?
' dependent variables of all series must be continues
series y1 = dlog(us_dollar)
series y2 = dlog(euro)
series y3 = dlog(pound_sterling)
series y4 = dlog(japanese_yen)
' set sample
' first observation of s1 need to be one or two periods after
' the first observation of s0
sample s0 1/4/1999 6/12/2015
sample s1 1/6/1999 6/12/2015
' initialization of parameters and starting values
' change below only to change the specification of model
smpl s0
'get starting values from univariate GARCH
equation eq1.arch(m=100,c=1e-5) y1 c
equation eq2.arch(m=100,c=1e-5) y2 c
equation eq3.arch(m=100,c=1e-5) y3 c
equation eq4.arch(m=100,c=1e-5) y4 c
' declare coef vectors to use in GARCH model
coef(4) lambda
lambda (1) = eq1.c(1)
lambda (2) = eq2.c(1)
lambda (3) = eq3.c(1)
lambda (4) = eq4.c(1)
coef(4) mu
mu(1) = eq1.c(1)
mu(2) = eq2.c(1)
mu(3) = eq3.c(1)
mu(4) = eq4.c(1)
coef(10) omega
omega(1) = (eq1.c(2))^.5
omega(2) = 0
omega(3) = 0
omega(4) = 0
omega(5) = eq2.c(2)^.5
omega(6) = 0
omega(7) = 0
omega(8) = eq3.c(2)^.5
omega(9) = 0
omega(10) = eq4.c(2)^.5
coef(4) alpha
alpha(1) = (eq1.c(3))^.5
alpha(2) = (eq2.c(3))^.5
alpha(3) = (eq3.c(3))^.5
alpha(4) = (eq4.c(3))^.5
coef(4) beta
beta(1) = (eq1.c(4))^.5
beta(2) = (eq2.c(4))^.5
beta(3) = (eq3.c(4))^.5
beta(4) = (eq4.c(4))^.5
' use sample var-cov as starting value of variance-covariance matrix
series cov_y1y2 = @cov(y1-mu(1), y2-mu(2))
series cov_y1y3 = @cov(y1-mu(1), y3-mu(3))
series cov_y1y4 = @cov(y1-mu(1), y4-mu(4))
series cov_y2y3 = @cov(y2-mu(2), y3-mu(3))
series cov_y2y4 = @cov(y2-mu(2), y4-mu(4))
series cov_y3y4 = @cov(y3-mu(3), y4-mu(4))
series var_y1 = @var(y1)
series var_y2 = @var(y2)
series var_y3 = @var(y3)
series var_y4 = @var(y4)
series sqres1 = (y1-mu(1))^2
series sqres2 = (y2-mu(2))^2
series sqres3 = (y3-mu(3))^2
series sqres4 = (y4-mu(4))^2
series res1res2 = (y1-mu(1))*(y2-mu(2))
series res1res3 = (y1-mu(1))*(y3-mu(3))
series res1res4 = (y1-mu(1))*(y4-mu(4))
series res2res3 = (y2-mu(2))*(y3-mu(3))
series res2res4 = (y2-mu(2))*(y4-mu(4))
series res3res4 = (y3-mu(3))*(y4-mu(4))
' constant adjustment for log likelihood
!mlog2pi = 4*log(2*@acos(-1))
' LOG LIKELIHOOD
' set up the likelihood
' 1) open a new blank likelihood object name tvgarch
' 2) specify the log likelihood model by append
logl fvgarch
' squared errors and cross errors
fvgarch.append @logl logl
fvgarch.append sqres1 = (y1-mu(1))^2
fvgarch.append sqres2 = (y2-mu(2))^2
fvgarch.append sqres3 = (y3-mu(3))^2
fvgarch.append sqres4 = (y4-mu(4))^2
fvgarch.append res1res2 = (y1-mu(1))*(y2-mu(2))
fvgarch.append res1res3 = (y1-mu(1))*(y3-mu(3))
fvgarch.append res1res4 = (y1-mu(1))*(y4-mu(4))
fvgarch.append res2res3 = (y2-mu(2))*(y3-mu(3))
fvgarch.append res2res4 = (y2-mu(2))*(y4-mu(4))
fvgarch.append res3res4 = (y3-mu(3))*(y4-mu(4))
' variance and covariance series
fvgarch.append var_y1 = omega(1)^2 + beta(1)^2*var_y1(-1) + alpha(1)^2*sqres1(-1)
fvgarch.append var_y2 = omega(2)^2+omega(5)^2 + beta(2)^2*var_y2(-1) + alpha(2)^2*sqres2(-1)
fvgarch.append var_y3 = omega(3)^2+omega(6)^2+omega(8)^2 + beta(3)^2*var_y3(-1) + alpha(3)^2*sqres3(-1)
fvgarch.append var_y4 = omega(4)^2+omega(7)^2+omega(9)^2 +omega(10)^2+ beta(4)^2*var_y4(-1) + alpha(4)^2*sqres4(-1)
fvgarch.append cov_y1y2 = omega(1)*omega(2)* + beta(2)*beta(1)*cov_y1y2(-1) + alpha(2)*alpha(1)*res1res2(-1)
fvgarch.append cov_y1y3 = omega(1)*omega(3) + beta(3)*beta(1)*cov_y1y3(-1) + alpha(3)*alpha(1)*res1res3(-1)
fvgarch.append cov_y1y4 = omega(1)*omega(4) + beta(4)*beta(1)*cov_y1y4(-1) + alpha(4)*alpha(1)*res1res4(-1)
fvgarch.append cov_y2y3 = omega(2)*omega(3) + omega(4)*omega(5) + beta(3)*beta(2)*cov_y2y3(-1) + alpha(3)*alpha(2)*res2res3(-1)
fvgarch.append cov_y2y4 = omega(2)*omega(4) + omega(5)*omega(6) + beta(4)*beta(2)*cov_y2y4(-1) + alpha(4)*alpha(2)*res2res4(-1)
fvgarch.append cov_y3y4 = omega(3)*omega(5) + omega(6)*omega(7) + beta(3)*beta(4)*cov_y3y4(-1) + alpha(3)*alpha(4)*res3res4(-1)
' determinant of the variance-covariance matrix
fvgarch.append deth = var_y1*var_y2*var_y3*var_y4-var_y1*cov_y3y4*cov_y2y3^2-cov_y1y2^2*var_y4+2*cov_y2y3*cov_y3y4*cov_y1y4-cov_y1y4^2*
var_y3+2*cov_y1y2*cov_y2y3*cov_y1y3*cov_y2y4-cov_y2y4^2*cov_y2y3*cov_y1y2*cov_y1y4*cov_y3y4-cov_y3y4^2*var_y2
' calculate the elements of the inverse of var_cov (H) matrix
' numbered as vech(inv(H))
fvgarch.append invh1 = (var_y3*var_y4-cov_y3y4^2)/deth
fvgarch.append invh2 = -(cov_y1y2*var_y4- cov_y1y3*cov_y1y4* cov_y2y3* cov_y2y4*cov_y3y4*)/deth
fvgarch.append invh3 = (cov_y1y2*cov_y2y3*cov_y1y3* cov_y2y4*cov_y3y4-cov_y1y4*var_y3)/deth
fvgarch.append invh4 = (var_y1*var_y4-cov_y1y4^2)/deth
fvgarch.append invh5 = -(var_y1*cov_y2y3-cov_y1y2*cov_y1y3 * cov_y2y4*cov_y3y4*cov_y1y4)/deth
fvgarch.append invh6= (var_y2*var_y4-cov_y2y4^2)/deth
fvgarch.append invh7 = (cov_y1y2*cov_y2y3*cov_y1y4* cov_y2y4*cov_y3y4-cov_y1y3*var_y2)/deth
fvgarch.append invh8= (var_y1*var_y2-cov_y1y2^2)/deth
fvgarch.append invh9= (var_y1*var_y3-cov_y1y3^2)/deth
fvgarch.append invh10 = (var_y2*var_y3-cov_y2y3^2)/deth
fvgarch.append invh11 = (cov_y1y2*cov_y2y3*cov_y1y3* cov_y1y4*cov_y3y4-cov_y2y4*var_y3)/deth
fvgarch.append invh12 = -(var_y1*cov_y3y4-cov_y1y2*cov_y1y3 * cov_y2y3*cov_y2y4*cov_y1y4)/deth
' log-likelihood series
tvgarch.append logl = -0.5*(!mlog2pi + (invh1*sqres1+invh4*sqres2+invh6*sqres3 ++invh8*sqres4 +invh9*sqres5 + invh10*sqres6 +2*invh2*res1res2 +2*invh3*res1res4+2*invh5*res2res3) + 2*invh7*res1res3)+2*invh11*res2res4)+ 2*invh12*res1res3)+log(deth))
' remove some of the intermediary series
'tvgarch.append @temp invh1 invh2 invh3 invh4 invh5 invh6 invh7 invh8 invh9 invh10 invh11 invh12 sqres1 sqres2 sqres3 sqres4 res1res2 res1res3 res2res3 deth
' estimate the model
smpl s1
tvgarch.ml(showopts, m=100, c=1e-5)
' change below to display different output
show tvgarch.output
graph var.line var_y1 var_y2 var_y3 var_y4
graph cov.line cov_y1y2 cov_y1y3 cov_y2y3 cov_y1y4 cov_y2y4 cov_y3y4
show var
show cov
' LR statistic for univariate vs trivariate
scalar lr = -2*(eq1.@logl + eq2.@logl + eq3.@logl + eq4.@logl - fvgarch.@logl)
scalar lr_pval = 1 - @cchisq(lr,4)
' set sample
smpl s0
coef(4) lambda
coef(4) mu
mu(1) = eq1.c(1)
mu(2) = eq2.c(1)
mu(3) = eq3.c(1)
mu(4) = eq4.c(1)
coef(10) omega
omega(2) = 0
omega(3) = 0
omega(4) = 0
omega(6) = 0
omega(7) = 0
omega(9) = 0
coef(4) alpha
coef(4) beta
' LOG LIKELIHOOD
logl fvgarch
smpl s1
show tvgarch.output
show var
show cov
