Confidence Interval
Posted: Thu Oct 31, 2013 5:45 am
by imran farooq
Sir,
I want to know about the confidence interval that is basically use by eviews. When i use SPPSS and Stata soft wear we set the confidence interval on our wish and after result the signification sign (*) automatically display. SO please guide me it is possible in eview that it shows the automatically.
Re: Confidence Interval
Posted: Thu Oct 31, 2013 7:37 am
Confidence interval on what?
Posted: Fri Nov 01, 2013 11:35 pm
by imran farooq
When we do a research we choose a confidence level like 0.001, 0.01, 0.95 and regress the equation, after regress the equation if variable is significant then a significant sign shows on as 0.009***etc.so i want to apply significance level which display automatically when we regress any equation and i am using eviws 07.
Posted: Sat Nov 02, 2013 7:12 am
View->Coefficient Diagnostics.
Posted: Sun Nov 03, 2013 1:54 am
by imran farooq
Thx for it but i want that significant sign like * can be show automatically, if the variable is significant. Please guide me a command or way that show the significant sign
Posted: Sun Nov 03, 2013 5:25 am
by trubador
There is an EViews add-in that does what you want in a different way. You can find the details here: http://forums.eviews.com/viewtopic.php?f=23&t=2131
I slightly modified that add-in so as to highlight significant coefficients with varying number of asterisks. Just download and install the add-in, and then replace the program file with the one attached.
You can also modify it further to suit your needs.
Posted: Mon Nov 04, 2013 5:55 am
by ch2324
the significant coefficients can not chow asterisks for GARCH model, can you modified it to chow for GARCH.
