function fracdiff
Posted: Sat Oct 26, 2013 12:50 pm
by ecofin
hi, I have a suggestion for fractional difference if it is possible
, to create a function fracdiff(x,n) in EViews 8 when "n" take the real number or to improve the function d(x,n). this function is necessary to automatic forecast the series x or fracdiff(x).
Re: function fracdiff
Posted: Mon Oct 28, 2013 9:43 am
by EViews Glenn
You might want to look at the fracdiff add-in
http://www.eviews.com/Addins/addins.shtml
Posted: Tue Oct 29, 2013 9:24 am
by ecofin
thank's for your reply
I know, I explain i have 'sp500' series (2100 obs daily) I made dlog(sp500) next I test the long memory...etc (d=0.33) for example.
now I estimate the model ARFIMA(1; 0.33; 1) for example.
I want to know if I can make a forecast of 'sp500' series, I can just make fracdiff series to forecat. because there is no function fracdiff(x) in eviews 8.
you understood me, is there a solution.
Posted: Tue Oct 29, 2013 1:04 pm
by EViews Glenn
I'm not sure I understand the question. The fracdiff add-in will compute the fractional difference of a series (where the difference parameter can take non-integer values).
Posted: Sun Nov 03, 2013 10:54 am
by ecofin
thanks for your reply
you can improve d(x,n) dlog(x,n) when 'n' take the real or natural numbers, or create a new Time Series Function such as fracdiff(x,n)
best regards
Posted: Mon Nov 04, 2013 2:03 pm
by EViews Glenn
Thanks for the suggestion. I just wanted to make certain that you understood that in the interim you can use the add-in to perform this operation.
Posted: Tue Nov 05, 2013 1:30 am
by ecofin
thank's for your reply.
