@nan function
Posted: Thu May 28, 2009 7:14 am
by Martin
A daily variable is available in excel format for each year; in other words one spreadsheet per year. Time period is from 1967-2008. I created a workfile with this range and created a series for each year that has observed values for that year and N/A for every other observation. I would now like to merge every series.
Is their another function like @nan? Or a procedure I can follow to merge these series so I will have a value for each observation?
Thank you
Martin
Re: @nan function
Posted: Thu May 28, 2009 7:55 am
Thank you
Martin
You can change the NAs to zeros, and then add the series. Something like
series allyears = @nan(y1,0)+@nan(y2,0)
Re: @nan function
Posted: Thu May 28, 2009 9:18 am
by Martin
Thank you Startz.
Unfortunately, some values need to remain N/A. In a specific year, one or two days of data might be missing. Is there another method to merge the series? I have been use @nan over and over. It gets the job done but it is time consuming.
Re: @nan function
Posted: Thu May 28, 2009 9:36 am
It seems you've gone about this somewhat backwards.
I think what I would do would be to create an EViews page for each year (i.e. an EViews page for each Excel sheet you have). Then you can use the EViews page append to append all those pages into one big page.
Re: @nan function
Posted: Thu May 28, 2009 9:40 am
Gareth is correct, but given where you are at the moment, if I understand the exercise correctly, the @RMEAN (or @RSUM) function should do what you want...
Suppose we have the two series X1 and X2 where we have
X1 X2 ------- 1 NA 2 NA NA 3 NA 4 NA NA
Form a group containing the two series
group allseries x1 x2
Then the command
series joined = @rmean(allseries)
will create
JOINED -------- 1 2 3 4 NA
Note that this works assuming that there is at most one value in the group that is valid for a given observation. You can check this restriction using @ROBS.
Re: @nan function
Posted: Thu May 28, 2009 10:36 am
by Martin
Then the command
will create
PERFECT! Seriously you’re my hero.
