Hello dear Eviews Helpers! Desperately need your help and will be greatful for any advice!
I have made a model using VEC in which I have exogenous variables, I can solve the model, but when it gets to forecasting I get confused, I can easily forecast endogenous variables, but don't understand how to treat exogenous in order to be able to solve the model for the forecasted period. Thanks in advance!
forecasting exogenous variables
Re: forecasting exogenous variables
They're exogenous. They can't be forecasted by the model (that's what exogenous means!). So how would you like to treat them?
Thank you for a quick reply, I have probably explained my problem incorrectly. I have actual monthly data from 2002 to 2012, I make a model based on VEC results, solve my model to see if it works (deterministic-static solution), then check the same period for dynamic solution, change my sample to 2020 to get a forecast and I can't solve the model in which I have 3 exogenous variables, it says missing data... if I change all exogenous to endogenous then I get a forecast, but it looks weird. So my question is how to perform a forecast with exogenous variables, so there would be no failure due to missing data. (For forecast, I solve stochastic-dynamic solution).Thanks
That's because the values of the exogenous variables from 2013 to 2020 are missing. You need to supply values for these variables.Thank you for a quick reply, I have probably explained my problem incorrectly. I have actual monthly data from 2002 to 2012, I make a model based on VEC results, solve my model to see if it works (deterministic-static solution), then check the same period for dynamic solution, change my sample to 2020 to get a forecast and I can't solve the model in which I have 3 exogenous variables, it says missing data... if I change all exogenous to endogenous then I get a forecast, but it looks weird. So my question is how to perform a forecast with exogenous variables, so there would be no failure due to missing data. (For forecast, I solve stochastic-dynamic solution).Thanks
but I don't understand how to get the data for the exogenous variables from 2012 to 2020 if it's a forecast? Do I make them up? write somewhere? could someone please provide an instruction on how I can feel that missing data for my exogenous variables! Thanks a lot!
There is no right answer. By stating that they are exogenous, you are stating that they are determined outside of the model. How they are determined is entirely up to you.
So, from what I understood from the replies: I need to fill the missing data for my exogenous variables in order to solve my model up until 2020. But how????I tried creating a model with all endogenous variables and then just exclude, so that they will be treated as exogenous and created a scenario, but it didn't work and I am really confused. Can you write a step-by step instruction on what to do to fill my data?please&
Open up each of the exogenous series, click the edit button and enter the numbers you want one by one.
