News Impact Curve
Posted: Tue May 26, 2009 11:18 am
by trubador
Below is an example code for plotting the News Impact Curve (NIC). The code first simulates an EGARCH(1,1) model, and then generates the graph of (a version of) NIC. Main purpose of the code is to give the basic idea behind the NIC and therefore should be modified for more specific cases. And the usual disclaimer applies.
'News Impact Curve Example for EGARCH(1,1) Model 'Obtaining a feasible curve depends on the significance of parameter values, 'which you may fail to obtain in each run. '************************************************************************************* 'THIS SECTION SIMULATES AND ESTIMATES AN EGARCH(1,1) MODEL '************************************************************************************* 'Decide a range and create a workfile !range = 200 wfcreate u !range 'Assign initial values to series smpl @first @first series res = 1 series gar =1 series y = 1 'Simulate an EGARCH(1,1) model coef(5) theta theta(1) = 2 theta(2) = .1 theta(3) = .5 theta(4) = .3 theta(5) = .6 for !i=1 to !range-1 smpl !i+1 !i+1 gar = exp(theta(2) + theta(3)*@abs(res(-1)/gar(-1)) + theta(4)*(res(-1)/gar(-1)) + theta(5)*log(gar(-1))) res = @sqrt(gar)*nrnd y = theta(1)+res next smpl @all delete gar res 'Estimate the EGARCH(1,1) model with the above generated series equation eq01.arch(1,1,egarch) y c 'Retrieve residuals, conditional variance and standardized errors eq01.makeresids res_eq eq01.makegarch gar_eq series z = res_eq/@sqrt(gar_eq) 'Replace the estimated coefficent values with the old ones. for !i=1 to eq01.@ncoef theta(!i) = eq01.@coef(!i) next '************************************************************************************* 'THIS IS THE ACTUAL PART THAT GENERATES THE NEWS IMPACT CURVE '************************************************************************************* !uvar = @mean(gar_eq) 'An estimate of unconditional variance !np = 100 'Number of points !lb =-2*@round(@max(@abs(z))) 'Lower bound !ub =2*@round(@max(@abs(z))) 'Upper bound !s = (!ub-!lb)/(!np-1) 'Step size matrix(!np,2) nic 'Generate a matrix to store the components 'First observations of standardized error and conditional variance nic(1,1)=!lb nic(1,2)=exp(theta(2) + theta(3)*@abs(!lb-!s) + theta(4)*(!lb-!s) + theta(5)*log(!uvar)) 'Generate the components, columns being the standardized error and conditional variance, respectively. for !i=2 to !np nic(!i,1) = !lb+(!i-1)*!s nic(!i,2) = exp(theta(2) + theta(3)*@abs(nic(!i-1,1)) + theta(4)*(nic(!i-1,1)) + theta(5)*log(!uvar)) next 'Plot the News Impact Curve (NIC) nic.xypair delete gar_eq res_eq z
Re: News Impact Curve
Posted: Tue Aug 05, 2014 5:56 pm
by wonderland6
I'm not that clear with the steps but this is what I do.
1. Estimate the EGARCH model
2. Procs/Make Garch Variance Series, and name it garch01
3. Procs/Make Residual Series (ordinary), and name it resid1
4. Genr z=resid1/sqr (garch01) -- in this case, " resid1" is "u" and garch01 is actually the σ.
5. Use Excel to rearrange the series z from small to large, and name a new series "sig"
6. Command line --- series log(s)=α*abs(sig)-γ*(sig)
7. Open sig and s as a group, and then view-graph- xy line. (I would make the y-axis as conditional volatility instead of conditional variance)
In this way, I always find the positive impact is greater, however, in my EGARCH model, γ is negative and there should be a greater negative impact. Is there something wrong with my steps?
