control firm fixed effect
Posted: Tue Oct 08, 2013 9:28 am
by florriec
my regression model is logistic model, how can i create a Fixed Effect Dummies for controlling "firm" fixed effect.
@expand (XXXXXX)
thank you
Re: control firm fixed effect
Posted: Tue Oct 08, 2013 9:36 am
Do you have a panel workfile?
Posted: Wed Oct 09, 2013 5:24 am
by florriec
please see the attachment.
i create " series withinid =@obsid" for period fixed effects and "series cxid= @crossid" for firm (stock number) fixed effects.
if i want to havae period and firm fixed effect. wHAT is the command?? :D
i did try @expand (@obsid, @dropfirst) @expand @crossid, @dropfirst) .however, it shows " 751 is not a valid index for vector-series-coeffcient C)
THANK YOU
Posted: Wed Oct 09, 2013 7:52 am
Yep you'll have to use @expand in the way that you are. But you'll run out of room using the built in C coefficient vector, so you'll have to use your own coefficient vector. To do this, simply enter a different name (say "Beta") on the "Coefficient Name" box of the options tab of the estimation dialog.
Posted: Wed Oct 09, 2013 8:29 am
by florriec
however, since my estimation settings -- method --Binary , in its option tab, there isn't any "coefficient name".
so, what should i do?
Posted: Wed Oct 09, 2013 8:42 am
by florriec
i did try object--new object-matrix-vector-coef --type "beta"-- choose coefficient vector.
then in the estimation box type "turnover beta iroe........@expand(@obsid, @dropfirst) @expand(@crossid, @dropfirst).
and it shows like "beta is not a series".
Posted: Wed Oct 09, 2013 8:46 am
Are you using EViews 8?
Posted: Wed Oct 09, 2013 8:48 am
by florriec
e-views 6 :(
You're out of luck then.
Posted: Wed Oct 09, 2013 8:51 am
by florriec
So, that means i need to use E views 8 for getting the results.
how is about e views 7?
Only 8 allows you to change the default coefficient vector.
