Is it an error? the Forecasting in EViews Tutorials
Posted: Sun Oct 06, 2013 5:15 am
by maxchen
EV8 32bit, 2013-10-01 patch
try the follwoing code, data from http://www.eviews.com/Learning/AllTutorials.zip
%pt = "Z:\2013\DL\EV8\Forecasting\" %wf = %pt + "Results.wf1" wfopen %wf 'pptx p48-49, Example 10 smpl sample_est equation eq10.ls d(payroll) c ism tbill3m @expand(@month, @droplast) smpl sample_for freeze(gf10df) eq10.forecast(g,d) eq10_diff_dyn2 eq10_diff_dyn_sd2 freeze(gf10sf) eq10.fit(g,d) eq10_diff_stat2 eq10_diff_stat_sd2 graph gf_diff2.line eq10_diff_dyn2 eq10_diff_stat2 'remark: by forecasting the entire expression rather than the normalized variable '1 eq10_diff_dyn2 and eq10_diff_stat2 should be equal, and both have the same sample length, not that one longer than the other '2 for the sd, eq10_diff_dyn_sd2 and eq10_diff_stat_sd2 are equal and the equal sample length 'now we turn to forcast diff by (1) forecast level, (2) compute the diff freeze(gf10df0) eq10.forecast(g) eq10_dyn eq10_dyn_sd freeze(gf10sf0) eq10.fit(g) eq10_stat eq10_stat_sd genr eq10_diff_dyn3 = d(eq10_dyn) genr eq10_diff_stat3 = d(eq10_stat) graph gf_diff3.line eq10_diff_dyn3 eq10_diff_stat3 show gf_diff2 gf_diff3 'remark: here dynamic is diff from the static forecast. Compare gf10df0 and gf10sf0, the sd of dynamic is increasing
I think the Example 10 in p48-49 of the Tutorial14_BasicForecasting.pptx, the explanation seems to improper.
