illegal lag or index specification for coefficient C
Posted: Thu Oct 03, 2013 8:02 am
by Chuvaekek
Hi!.
I'm new to eviews. my problem is that my equation in ADF testing in level is
d(interest)=c+trend+interest(-1)+e
whenever i enter this equation that i learned from youtube, illegal lag or index specification for coefficient c was always showed.
pls help me!.
give me alternative equation or simple equation in ADF testing in level and in 1st difference
my variables are:
Interest, inflation, forex, m2, financials, industrial and property
Re: illegal lag or index specification for coefficient C
Posted: Thu Oct 03, 2013 8:05 am
I'm going to assume you just want to estimate an equation, and I'm going to ignore the part about ADF testing (since it doesn't make sense)...
Enter your equation as:
Posted: Thu Oct 03, 2013 8:24 am
by Chuvaekek
doesn't work either. trend is not defined.
im using eviews 6.
i have another question.how can i convert may data into non-stationary data and stationary data?
thank you.
Posted: Thu Oct 03, 2013 8:34 am
d(interest) c @trend interest(-1)
Posted: Thu Oct 03, 2013 8:46 am
by Chuvaekek
it didn't work. anyway. if my data has a unit root, it will stay as it is. but how will i generate new data in 1st difference?
Posted: Thu Oct 03, 2013 9:24 am
by startz
Posted: Sat Oct 19, 2013 9:57 am
by Chuvaekek
thank you startz
anyway. I used 1st differenced data in cointegration and granger. i did the test in groups. e.g. 1 independent variables and 3 dependent. the result showed that all of them have cointegrating relation. however, when i run the variables in pair. they dont established cointegrating relation but the granger results that the ind granger cause the dep variable. Im confused. pls tell the what is the right step in testing the econometric?
thank you again
