Command for regression for specific year
Posted: Wed Oct 02, 2013 1:42 am
The data I'm using is panel data and the time period for the data is 7 years, from 2000 to 2007.
I am using Eviews 8.
I'm trying to write a command to create a simple linear regression that allows me to specify the year (e.g. year 2000 only, or a range, e.g. years 2000 to 2005) in which to run the equation. I am aware I can manually change the date range under 'Estimation settings'; Sample: "year range", however, is there a command for this in which I can add to the following equation command?:
equation eq01.ls y c x
