F2
Posted: Tue Sep 17, 2013 10:52 am
If you hit function key F2 in an equation window, an edit field opens. There doesn't appear to be a way to turn it off, except by resetting the View.
Is this the intended behavior?
Re: F2
Posted: Thu Sep 19, 2013 9:44 am
by EViews Jason
This is intended behavior. If you press the right mouse button and select Edit+/-. This will turn it off.
We will look into toggling Edit mode with F2 key presses whereas right now it only turns it on.
