Accessing "Print Setup" from a program
Posted: Fri May 22, 2009 6:23 am
by fbrayton
Is it possible to set or alter the "Print Setup" entries from within a program? I don't see any documentation on how to do this, so perhaps it isn't. Specifically, we want a batch program to print a spool object to a PDF file. This program will be run by many different people, and so I'd like the program to select our PDF printer automatically and to specify a run-specific name of the PDF file.
Re: Accessing "Print Setup" from a program
Posted: Fri May 22, 2009 8:16 am
by EViews Jason
You can turn on/off printer redirection via the 'output' command. For example:
output(s) myspool 'have all prints commands print to 'myspool' print mytable 'adds a copy of the object mytable to myspool output off 'turn off print redirection and print to the printer print mytable 'sends mytable to the currently set printer
But there currently isn't a command to set which printer you wish to print to.
