Page 1 of 2
Using import/wfopen instead of read
Posted: Mon Sep 16, 2013 12:50 am
by Vladimir_Yorrick
Can someone please help me with an efficient use of import or wfopen instead of read in:
wfcreate a 1995 2015 for %sheet sheet1 sheet2 sheet3 sheet4 sheet5 read(t,d4,s={%sheet}) data.xls 5 next
The code above is nice since it automatically reads in the variable names (located in column c). FYI, '5' is the number of rows of data.
I'd like to not use read, which will also let me use a .xlsx instead of .xls file.
Thanks in advance for any suggestions.
Re: Using import/wfopen instead of read
Posted: Mon Sep 16, 2013 7:28 am
wfopen data.xls range="Sheet1!c1:x9" byrow
Posted: Tue Sep 17, 2013 5:10 pm
by Vladimir_Yorrick
Thanks for the suggestion.
A couple more questions:
1. How can I make it read in or create the dates (i.e. 1995 2015)?
2. I actually have more like 40 worksheets. How would I make it import the data (all located in the same cell locations) in all sheets in as few lines of code as possible, since
wfopen data.xls range="Sheet1!c1:x9" range="Sheet2!c1:x9" range="Sheet3!c1:x9" range="Sheet4!c1:x9" range="Sheet5!c1:x9" byrow
doesn't do what I want it to do and
wfopen data.xls range="Sheet1!c1:x9" byrow wfopen data.xls range="Sheet2!c1:x9" byrow wfopen data.xls range="Sheet3!c1:x9" byrow wfopen data.xls range="Sheet4!c1:x9" byrow wfopen data.xls range="Sheet5!c1:x9" byrow
opens 5 separate workfiles when I'd like all the data to be imported into the one workfile (plus, with aropund 40 worksheets it's gonna take 40 lines in the program?
Thanks again for any suggestions.
Posted: Tue Sep 17, 2013 5:21 pm
The code I provided does read in the dates.
Use IMPORT rather than WFOPEN to import into an existing workfile.
Posted: Wed Sep 18, 2013 10:12 pm
by Vladimir_Yorrick
Thanks very much Gareth for your suggestion.
This does what I want it to do:
wfopen data.xls range="Sheet1!c1:x8" byrow import data.xls range="Sheet2!c1:x8" byrow import data.xls range="Sheet3!c1:x8" byrow import data.xls range="Sheet4!c1:x8" byrow import data.xls range="Sheet5!c1:x8" byrow 'import data.xls range="Sheet6!c1:x8" byrow 'import data.xls range="Sheet7!c1:x8" byrow 'import data.xls range="Sheet8!c1:x8" byrow 'import data.xls range="Sheet9!c1:x8" byrow '... 'import data.xls range="Sheet40!c1:x8" byrow delete series* 'Delete the first three rows, the first being the date and the second two are left blank intentionally
But with around 40 Excel worksheets would you be able to suggest a more efficient or neater way of doing this?
FYI, I am currently doing something like:
wfcreate a 1995 2015 for %sheet sheet1 sheet2 sheet3 sheet4 sheet5 ... sheet40 read(t,d4,s={%sheet}) data.xls 5 next
which, though it uses Read (which I am trying to avoid), takes only 4 lines. Can I use string lists in range? (something like range={%sheet}+"!c1:x8")
Posted: Thu Sep 19, 2013 7:48 am
%range = %sheet + "!c1:x8" import data.xls range=%range byrow
Posted: Fri Sep 20, 2013 12:53 am
by Vladimir_Yorrick
Hi Gareth,
I don't mean to be annoying but something is bothering me.
Could you please try the sequence of experiments below.
1. Using the data.xls file above, run:
tic wfcreate a 1995 2015 for %sheet sheet1 sheet2 sheet3 sheet4 sheet5 read(t,s={%sheet},d4) data.xls 5 next !elapsed = @toc statusline !elapsed seconds
The average of five runs is 0.08 seconds.
2. Now run:
tic wfcreate a 1995 2015 for %sheet sheet1 sheet2 sheet3 sheet4 sheet5 %range=%sheet+"!c1:x8" import data.xls range=%range byrow next delete series02 series03 !elapsed = @toc statusline !elapsed seconds
This averages 0.16 seconds, an average of 2.3 times slower than Experiment 1.
3.Now, save the file in .xlsx format (which is what I would normally do when not using 'read') and run:
tic wfcreate a 1995 2015 for %sheet sheet1 sheet2 sheet3 sheet4 sheet5 %range=%sheet+"!c1:x8" import data.xlsx range=%range byrow next delete series02 series03 !elapsed = @toc statusline !elapsed seconds
This takes on average 0.99 seconds, which is 14 times slower than Experiment 1.
The data.xls(x) file is just an example for this posting. Using my actual data (Excel) file, which has around 40 worksheets:
- Using 'read' averages 0.23 seconds
- Using 'import' (with a .xlsx file) averages 17.24 seconds, which is 88 times slower
- Using 'import' (with a .xls file) averages 1.55 seconds, which is 8 times slower.
I've noticed the statusline saying 'Uncompressing file' when I use 'import' with a .xlsx file.
I guess my question is: Why is using 'import' (which is what I want to use) so much slower than using 'read'? [Using import is far quicker with an Excel 2003 file but still considerably slower than using read.]
If this is just the way it is then no worries. But I am just wondering how I can make wfopen/import work for me since I wanna move away from using read, but when it takes almost 20 seconds to run a program it is a bit annoying.
Thanks for looking at this.
Vlad.
Posted: Wed Sep 25, 2013 4:48 pm
by Vladimir_Yorrick
I'm hoping to get some advice on using 'import' with Excel 2010 (.xlsx) files.
With Gareth's help, I can import my data (very straighforward stuff/arrangement, nothing tricky, all 'tables' of same dimensions) without problems.
But it is slow. It takes almost 20 seconds to run the program where all it does it import the data.
The one thing I notice is, whilst importing, the statusline says 'Uncompressing file...'.
'Import' is a lot quicker using the same file but saved in an .xls (as opposed to .xlsx) format. Using the old 'read' and not using 'wfopen/import' altogther runs the way it should ... blink of an eye.
What am I not understanding?
Thanks in advance.
Vlad.
Posted: Wed Sep 25, 2013 5:34 pm
.xslx is a compressed file format. .xls is not.
Try running the program whilst the file is open in Excel. Should be much faster (since Excel has already uncompressed).
Posted: Wed Sep 25, 2013 6:51 pm
by Vladimir_Yorrick
Cool, thanks Gareth. It now runs in half the time (and having the Excel file open is actually what I'd prefer).
One thing though ... in my case using import is still considerably slower than using the old read command (with a .xls file). I wonder if it's because import caters for many more 'arguments' than read and it searches for those before running and since I'm reading my data using a loop with many import statements the time just adds up.
Posted: Wed Sep 25, 2013 7:54 pm
It is just the increased intelligence of import over read. It takes longer to analyze the data. Especially if it is byrow.
Posted: Thu Aug 09, 2018 7:29 am
by farrel
Dear Gareth,
I tried running the program, while the EXCEL file is open, but I've got error message saying "Sharing violation for file 'C:\USERS ....". There is no error with EXCEL being closed.
How did you mean to run Eviews program with EXCEL being open?
Andrei
Posted: Thu Aug 09, 2018 7:55 am
Are you sure it was an Excel file and not a CSV file?
Posted: Fri Aug 10, 2018 5:48 am
by farrel
as I see it - Yes! at least I judge the file by extension, which is ".xlsx"
Posted: Mon Aug 13, 2018 11:28 pm
by farrel
Gareth,
Whether your Eviews is working with opened EXCEL (.xlsx) file?
