weighted least squares R^2
Posted: Sat Sep 14, 2013 8:31 am
I do not understand what R^2 is in the WLS output.
In the Weighted Least Squares output, the manual states the statistics are from the actual estimated equation.
If that means R^2 is computed as 1 minus Residual SS / Total SS , and we use the output, the R^2 computed that
way is not the reported R^2.
Example:
Dependent Variable: LRATMUR
Method: Least Squares
Date: 09/13/13 Time: 13:55
Sample: 1 703
Included observations: 703
Weighting series: 1/DENSITY
Weight type: Inverse standard deviation (no scaling)
C 6.941144 1.473009 4.712220 0.0000
LOG(RPCPI) 0.243077 0.167021 1.455373 0.1460
LOG(ARRMURD) -0.720749 0.030417 -23.69553 0.0000
LOG(CONVMURD) -0.665553 0.030671 -21.69945 0.0000
LOG(DENSITY) -0.320790 0.030445 -10.53667 0.0000
LOG(PPB) 0.002043 0.023552 0.086740 0.9309
Weighted Statistics
R-squared 0.615787 Mean dependent var 0.057614
Adjusted R-squared 0.613031 S.D. dependent var 0.150715 R^2 = 1 - 0.686284/(0.150715*(703-6))=1-0.686284/15.94545=.956951
S.E. of regression 0.031379 Akaike info criterion -4.076874
Sum squared resid 0.686284 Schwarz criterion -4.037995
Log likelihood 1439.021 Hannan-Quinn criter. -4.061848
F-statistic 223.4198 Durbin-Watson stat 1.678864
Prob(F-statistic) 0.000000 Weighted mean dep. 2.490813
Unweighted Statistics
R-squared -0.073278 Mean dependent var 1.691755
Adjusted R-squared -0.080977 S.D. dependent var 0.841445
S.E. of regression 0.874851 Sum squared resid 533.4590
Durbin-Watson stat 0.796153
And that agrees with the R^2 calculated in a least squares with weighted variables
Dependent Variable: LRATMUR/DENSITY
Date: 09/14/13 Time: 10:15
Sample: 1 703
1/DENSITY 6.941144 1.473009 4.712220 0.0000
LOG(RPCPI)/DENSITY 0.243077 0.167021 1.455373 0.1460
LOG(ARRMURD)/DENSITY -0.720749 0.030417 -23.69553 0.0000
LOG(CONVMURD)/DENSITY -0.665553 0.030671 -21.69945 0.0000
LOG(DENSITY)/DENSITY -0.320790 0.030445 -10.53667 0.0000
LOG(PPB)/DENSITY 0.002043 0.023552 0.086740 0.9309
R-squared 0.956962 Mean dependent var 0.057614
Adjusted R-squared 0.956653 S.D. dependent var 0.150715
Another interpretation (and the original) is the correlation squared between the actual and the predicted.
The correlation is .978249 which squared is .956971 -
So what is 0.615787???
Additionally, what is the unweighted NEGATIVE R^2? Yes it is calculated as 1 - RSS/TSS from
R-squared -0.07327801 Mean dependent var 1.691754524
Adjusted R-squared -0.080977278 S.D. dependent var 0.841445199
S.E. of regression 0.874851054 Sum squared resid 533.4589635
Durbin-Watson stat 0.796153391
but what do those numbers mean (what are their exact formulas)
Bob
Example:
Sample: 1 703
Weighted Statistics
Sample: 1 703
Bob
