For loop problem
Posted: Tue Sep 10, 2013 2:36 am
by Karl1
The code below only loops through the first variable in the outer loop. The outer loop uses only "TSTI" and "PS1" and not "TSTII" and "PS2". If I copy and past the commands and use TSTI and PS1 in the copied paragraph and TSTII and PS2 in the pastet paragraph, it works. I don't see why the loop shouldn't do the same. Sorry for the long batch. It is all a part of a large batch file.
series PS1 series PS2 group gr2 TSTI TSTII ' the variable names group gr6 PS1 PS2 'scenario alias !ngr2 = gr2.@count for !i = 1 to !ngr2 %str6 = gr6.@seriesname(!i) %str2 = gr2.@seriesname(!i) SERIES {%str2}_{%str6} = {%str2} SMPL 2012q3 2017q4 SERIES {%str2}_{%str6} = {%str2}*0.5 MOD_2SLS.SCENARIO(N, A=_{%str6}) "SCENARIO" {%str6} MOD_2SLS.OVERRIDE {%str2} MOD_2SLS.SCENARIO(C) "BASELINE" MOD_2SLS.SOLVEOPT(M=5000, S=A, D=D, R=1000, B=0.95, A=T, O=G, CU=T) MOD_2SLS.SOLVE group gr1 AB AC AD AE AF AG AH AI AJ AK AL AM AN AO AP AQ AR AS AT AU !n1 = gr1.@count for !i=1 to !n1 %str1 = gr1.@seriesname(!i) MOD_2SLS.MAKEGRAPH( c, S=m, G=v) GRAPH_{%str2}_{%str1} {%str1} next group gr3 AB AC AD AE AF AG AH AI AJ AK AL AM AN AO AP AQ AR AS AT AU group gr4 "1" "2" "3" "4" "5" "6" "7" "8" "9" "10" "11" "12" "13" "14" "15" "16" "17" "18" "19" "20" !n1 = gr3.@count for !i=1 to !n1 %str3 = gr3.@seriesname(!i) %str4 = gr4.@seriesname(!i) graph_{%str2}_{%str3}.legend -display graph_{%str2}_{%str3}.addtext(t) {%str4} next group gr5 AB AC AD AE AF !n1 = gr5.@count %grnames = "" for !loop = 1 to !n1 %grnames = %grnames + " " + "graph_" + %str2 + "_" + gr5.@seriesname(!loop) next graph graph_{%str2}_{%date}.merge {%grnames} graph_{%str2}_{%date}.axis(l) grid zeroline graph_{%str2}_{%date}.axis(b) grid graph_{%str2}_{%date}.addtext(t, x, font("Arial",24,+b,+i),just(c)) Stress {%str2} {%datelong}\r Stress values are blue, baseline values are green show graph_{%str2}_{%date}.align(4,1,1) next
Re: For loop problem
Posted: Tue Sep 10, 2013 6:46 am
You're re-setting !i inside the loop.
Posted: Tue Sep 10, 2013 7:22 am
by Karl1
Now you saved my day! Thank you!
