Automatic chart update
Posted: Tue Aug 27, 2013 8:09 am
by vytama
Hi, I have a few time series in a group. I have charts from the group and I have frozen charts with automatic update. However, the data in the group has changed but chart does not update automatically or if I click update button. Can you tell me what the problem is? Eviews 8 enterprize.
Re: Automatic chart update
Posted: Tue Aug 27, 2013 8:21 am
Can you provide the workfile?
Posted: Tue Aug 27, 2013 10:16 am
by vytama
I noticed that if I update underlaying series in the group, chart updates. My group has transformations (ratio of one series over another), if I change the formula in the group, chart does not update.
Posted: Tue Aug 27, 2013 10:41 am
by EViews Glenn
If I am understanding the question correctly it has to do with what defintions are stored in the updating graph. I believe that the graph object that you created uses the definitions at the time the graph was created. That is, if you have a group
x y x/y
and create an updating graph from it, the graph inherits the definitions in the group at the time it was created. It does not define itself in terms of the group object. Thus, changing x or y will change the values in the graph, but changing the definitions in the group will not.
Note that this behavior allows you to define a temporary group, create an updating graph from the group, and then delete the group.
Posted: Tue Aug 27, 2013 10:42 am
by vytama
Ok, thank you.
Posted: Fri Sep 06, 2013 8:45 am
by vytama
I have another question on charting. I have multiple pages with series with different frequences. Is there away to select or open charts together from separate pages? Is it possible to store charts from multiple pages on one page dedicated to charts only? Thanks.
Posted: Fri Sep 06, 2013 9:11 am
Yes, but not if you want them to auto-update.
