Create page with same frequency as first page
neptunhiker
Postby neptunhiker » Tue Aug 27, 2013 3:41 am
I can't figure out how to create a new page in the same workfile that has the same structure as Page1.
If I insert the following code, eViews gives me an error, because of an incomplete command.
create d5 2000 2002 series someseries pagecreate (byid) @date(someseries)
I think I get the error, because when I just insert the following code into the command window of an already created workfile, then a new window pops up and asks me to specify the structure of the new page to be created.
How can I avoid that? That is: What code can I insert into my program that creates a new page with the same structure as the "OldPage without having to confirm or specify anything?
Thanks a lot.
Re: Create page with same frequency as first page
Postby EViews Gareth » Tue Aug 27, 2013 8:26 am
create d5 2000 2002 pagecreate(byid) @date
Postby EViews Glenn » Tue Aug 27, 2013 10:42 am
I think the problem with the original example is the extra space before the options. EViews thinks you want to define the page using the series BYID.
neptunhiker
Postby neptunhiker » Tue Aug 27, 2013 10:27 pm
Thanks. It worked out perfectly. It was really just the space.
