Menu? Panel cointegration tests
Posted: Sun Aug 04, 2013 5:27 pm
dear forum,
I am trying to run Pedroni's panel co-integration test. I am using Eviews 8.
My data is structured as panel. To start co-integration test, I checked Eviews 8 help . It says "select views/cointegration test/panel cointegration".
however, I don't see this command under views. I rather see quick/group statistics/johansen co-integration test. when I run johansen, it automatically takes me to "panel co-integration tests"
Am I on the right track? Is my data correctly structured as panel? I carefully defined it as panel by following the directions here: http://www.eviews.com/Forum_support/pan ... ucture.htm
Can you check to see if my data is correct panel format? I have ATTACHED it. I don't see any command of "panel co-integration test" in Eviews 8. Instead, Johansen co-integration leads to panel co-integration test.
Is johasen and panel co-integration test the same?
I really appreciate your help. Thanks a lot in advance.
lnp3
Mine.D.
lnp3
Mine.D.
