Regime Switching
athens
Regime Switching
Postby athens » Mon Jul 29, 2013 4:37 pm
I am using Eviews 8 (62 bit) version and I have just updated it. When I run a regime switching model with 5 lags of the dependent and AR(1) error I get the following message "Eviews 8 has stopped working". I do not get the same message if I estimate a regime switching model with e.g. 4 lags of the dependent and AR(1) error.
My code is as follows:
equation eq1.switchreg(type=markov, heterr) y c y(-1) y(-2) y(-3) y(-4) y(-5) ar(1) @nv x1 x2
Please inform me if this is a bug or if I am doing something wrong. Thanks.
Re: Regime Switching
Postby EViews Gareth » Mon Jul 29, 2013 6:24 pm
Almost certainly a bug. Could you provide your workfile?
athens
Postby athens » Tue Jul 30, 2013 1:37 pm
regswitch_ex.wf1
(158.77 KiB) Downloaded 368 times
Postby EViews Glenn » Tue Jul 30, 2013 3:00 pm
Thanks. We've tracked this one down and after a bit more testing I'll check it into the main code. It should appear in the next update.
[edit: just to follow-up, this bugfix was posted in the August 1 update]
