Computing Forecast Evaluation Criteria
Posted: Thu May 14, 2009 5:44 am
Below is a short piece of code I've written as a subroutine for computing the forecast error statistics that EViews commonly reports. Although you may find it useful, it has not been tested/improved enough and is intended only to help you in obtaining these statistics effectively, where EViews does not automatically produce. Using the code is at your own risk...
'y is the dependent variable
'yf is the forecasted values of the dependent variable
's is the forecast sample and should be defined carefully beforehand (e.g. sample s 1997m04 2009m04)
sample my_sample beginning end
call forper(my_series,my_forecasts,my_sample)
subroutine forper(series y,series yf,sample s)
table(7,2) criteria
criteria.setwidth(A) 20
criteria.setjust(1,A,7,B) left
criteria.setindent(5,A,7,A) 8
smpl s
!h = @obssmpl
series ratio = yf/y
series one = 1
series dif= yf - y
!RMSE = @sqrt((@sumsq(dif))/!h)
!MAE = (@sum(@abs(dif)))/!h
!MAPE = 100*(@sum(@abs(one-ratio)))/!h
!THEIL = !RMSE / ( @sqrt((@sumsq(y))/!h) + @sqrt((@sumsq(yf))/!h))
!biasprop = (@mean(yf) - @mean(y))^2 / !RMSE^2
!varianceprop = (@sqrt(@var(yf)) - @sqrt(@var(y)))^2 / !RMSE^2
!covarianceprop = 2*(1-@cor(yf,y))*@sqrt(@var(yf))*@sqrt(@var(y)) / !RMSE^2
!i=1
for %c RMSE MAE MAPE THEIL Biasprop Varianceprop Covarianceprop
criteria(!i,1)=%c
%r = "!"+%c
criteria(!i,2)={%r}
!i=!i+1
show criteria
smpl @all
delete s ratio one dif
endsub
