Learning Eviews commands
Posted: Mon Jul 15, 2013 5:19 pm
by bobreednz
Hi, I would like to learn more about EViews programming. While the template programs are very helpful, I find that it is often helpful to use the drop-down menu, and then see the command syntax associated with the dialog box choices. For example, when I use Stata and make a command choice from the drop-down menu, the corresponding syntax shows up in the output window. Is there anything similar for EViews? For example, I was doing some unit root testing and wanted to write a program to record my commands, but had to fish around through the help functions to learn that the corresponding command was uroot. Is there an easier way to learn this"
Re: Learning Eviews commands
Posted: Mon Jul 15, 2013 9:54 pm
Unfortunately not.
