Unexpected substitution when fetching objects containing '%'
Posted: Thu Jun 13, 2013 11:13 am
by etienne
EViews does an unexpected substitution using the fetch or copy commands with series in remote databases containing the '%' symbol (fortunately, such series are not very common), if it contains within it the name of a control variable. Best viewed through an example.
The following:
%y = "test" fetch(d=uscen) dsr%yd.q
Will generate an error message: USCEN::DSR"TEST"D.Q was not found in "FETCH(D=USCEN) DSR"TEST"D.Q".
The '%y' of 'dsr%yd.q' has unexpectedly been replaced by the value of '%y'. The same happens using the copy command instead. A similar error would happen if '%yd' = "test"' was used instead of '%yd = "test"', since '%yd' is also included in 'dsr%yd.q', but defining '%ya' would avoid the problem. Isolating the request in a local subroutine doesn't help.
The only "solution" I've found is to avoid using control variables' names that would be a part of such a series name in the whole program. Not a major bug since it's relatively easy to work around, but I found it worth to submit it nonetheless.
Best regards,
Étienne
Re: Unexpected substitution when fetching objects containing
Posted: Thu Jun 13, 2013 11:16 am
by etienne
I forgot to mention that this happens in both versions 7.2 and 8.
Posted: Thu Jun 13, 2013 11:49 am
Have you tried:
fetch(d=uscen) "dsr%yd.q"
Posted: Thu Jun 13, 2013 12:38 pm
by etienne
Thanks, it leads to a better workaround than making sure control variables names are not part of the names of objects that could be fetched, because the following works:
%y = "test" %x = "dsr%yd.q" fetch(d=uscen) %x
with no curly braces around %x.
In the real world, in my programs, object names to import are almost always part of a list (a string of space-separated object names). If I have multiple objects within the list, omitting the curly braces around the control variable name will cause an error. For example,
%y = "test" %x = "gdpr.q dsr%yd.q" fetch(d=uscen) %x
will return an error, saying USCEN::"GDPR.Q DSR%YD.Q" was not found in "FETCH(D=USCEN) "GDPR.Q DSR%YD.Q".
The workaround seems to be to make a loop and fetch items separately, so I can omit the curly braces. This gives:
%y = "test" %x = "gdpr.q dsr%yd.q" for %i {%x} fetch(d=uscen) %i next
It's somewhat slower than a single fetch request, but more robust.
Best regards,
Étienne
Posted: Thu Jun 13, 2013 1:28 pm
How about:
%x = """gdpr.q"" ""dsr%yd.q""" fetch(d=uscen) %x
(I have no idea if that will help or not, just throwing things out there :D)
Posted: Fri Jun 14, 2013 6:17 am
by etienne
The latter did't work, but thanks anyway.
Étienne
