@uilist return value not consistent
Posted: Thu Jun 13, 2013 10:46 am
by etienne
The return values of the @uilist function doesn't behave the same depending on whether the select_item argument is a scalar or a string.
If the select_item argument is a scalar, then the command will return 0 when pressing the OK button, and -1 when pressing the Cancel button, as expected.
However, if the select_argument is a string, then the command will return 1 when pressing the OK button, and 0 when pressing the Cancel button.
This has been observed in both EViews versions 7.2 and 8.
As a workaround, in the meantime, I use @uidialog("List", ...) instead.
Best regards,
Étienne
Re: @uilist return value not consistent
Posted: Thu Jun 13, 2013 12:03 pm
Will be fixed in next EV8 patch.
