GARCH correlation matrix forecast
Posted: Tue Jun 11, 2013 4:20 am
by elias41
I created a system to estimate a diagonal VECH with
sys01.makegarch(mat,cor)
Is it possible to do a one step ahead dynamic forecast of the resulting garch matrix?
Regards,
Elias
Re: GARCH correlation matrix forecast
Posted: Tue Jun 11, 2013 5:39 am
by trubador
Posted: Tue Jun 11, 2013 6:10 am
by elias41
Thanks for your hint trubator. However, this procedure is cumbersome and not practical when estimating larger matrices or/ and when using TARCH. Isn't there a more elegant way available?
Posted: Tue Jun 11, 2013 11:53 pm
by elias41
Does really no one knows any approach?
Posted: Fri Jun 21, 2013 5:53 am
by elias41
I implemented the solution to the above problem for the diagonal VECH but encountered problems with GARCH negativity and computation time for large matrices. I found the BEKK approach more elegant in terms of parsimonious estimation and system stability. For everyone who is interested in making GARCH, more precisely TARCH, correlation matrix forecasts using a BEKK approach please see code below. After estimating the system and saving its parameter output one could continue with:
'retrieve parameter estimates for !i=1 to !n for !j=1+!i-1 to !n M(!i,!j) = sys01.@coefs(!coeff_counter) !coeff_counter=!coeff_counter+1 next next for !i=1 to !n A1(!i,!i) = sys01.@coefs(!coeff_counter) !coeff_counter=!coeff_counter+1 next for !i=1 to !n D1(!i,!i) = sys01.@coefs(!coeff_counter) !coeff_counter=!coeff_counter+1 next for !i=1 to !n B1(!i,!i) = sys01.@coefs(!coeff_counter) !coeff_counter=!coeff_counter+1 next 'forecast conditional variance if !n > 9 then for !i = 1 to 9 !longrun_cvar = M(!i,!i) / (1-A1(!i,!i)*A1(!i,!i) - 0.5*D1(!i,!i)*D1(!i,!i) - B1(!i,!i)*B1(!i,!i)) scalar garchf_{!i}=!longrun_cvar + (A1(!i,!i)*A1(!i,!i) + 0.5*D1(!i,!i)*D1(!i,!i) + B1(!i,!i)*B1(!i,!i))*(garch_0{!i}(!observations) - !longrun_cvar) next for !i = 10 to !n !longrun_cvar = M(!i,!i) / (1-A1(!i,!i)*A1(!i,!i) - 0.5*D1(!i,!i)*D1(!i,!i) - B1(!i,!i)*B1(!i,!i)) scalar garchf_{!i}=!longrun_cvar +(A1(!i,!i)*A1(!i,!i) + 0.5*D1(!i,!i)*D1(!i,!i) + B1(!i,!i)*B1(!i,!i))*(garch_{!i}(!observations) - !longrun_cvar) next Else for !i = 1 to !n !longrun_cvar = M(!i,!i) / (1-A1(!i,!i)*A1(!i,!i) - 0.5*D1(!i,!i)*D1(!i,!i) - B1(!i,!i)*B1(!i,!i)) scalar garchf_{!i}=!longrun_cvar + (A1(!i,!i)*A1(!i,!i) + 0.5*D1(!i,!i)*D1(!i,!i) + B1(!i,!i)*B1(!i,!i))*(garch_0{!i}(!observations) - !longrun_cvar) next endif 'forecast conditional covariance if !n > 9 then for !i=1 to 9 for !j=1+!i to 9 !longrun_ccov = M(!i,!j) / (1-A1(!i,!i)*A1(!j,!j) - 0.5*D1(!i,!i)*D1(!j,!j) - B1(!i,!i)*B1(!j,!j)) scalar covf_{!i}_{!j} = !longrun_ccov + (A1(!i,!i)*A1(!j,!j) + 0.5*D1(!i,!i)*D1(!j,!j) + B1(!i,!i)*B1(!j,!j))*(garch_0{!i}_0{!j}(!observations) - !longrun_ccov) scalar covf_{!j}_{!i} =covf_{!i}_{!j} next next for !i = 1 to 9 for !j = 10 to !n !longrun_ccov = M(!i,!j) / (1-A1(!i,!i)*A1(!j,!j) - 0.5*D1(!i,!i)*D1(!j,!j) - B1(!i,!i)*B1(!j,!j)) scalar covf_{!i}_{!j} = !longrun_ccov + (A1(!i,!i)*A1(!j,!j) + 0.5*D1(!i,!i)*D1(!j,!j) + B1(!i,!i)*B1(!j,!j))*(garch_0{!i}_{!j}(!observations) - !longrun_ccov) scalar covf_{!j}_{!i} =covf_{!i}_{!j} next next for !i = 10 to !n-1 for !j = !i + 1 to !n !longrun_ccov = M(!i,!j) / (1-A1(!i,!i)*A1(!j,!j) - 0.5*D1(!i,!i)*D1(!j,!j) - B1(!i,!i)*B1(!j,!j)) scalar covf_{!i}_{!j} = !longrun_ccov + (A1(!i,!i)*A1(!j,!j) + 0.5*D1(!i,!i)*D1(!j,!j) + B1(!i,!i)*B1(!j,!j))*(garch_{!i}_{!j}(!observations) - !longrun_ccov) scalar covf_{!j}_{!i} =covf_{!i}_{!j} next next Else for !i = 1 to !n-1 for !j = 1+!i to !n !longrun_ccov = M(!i,!j) / (1-A1(!i,!i)*A1(!j,!j) - 0.5*D1(!i,!i)*D1(!j,!j) - B1(!i,!i)*B1(!j,!j)) scalar covf_{!i}_{!j} = !longrun_ccov + (A1(!i,!i)*A1(!j,!j) + 0.5*D1(!i,!i)*D1(!j,!j) + B1(!i,!i)*B1(!j,!j))*(garch_0{!i}_0{!j}(!observations) - !longrun_ccov) scalar covf_{!j}_{!i} =covf_{!i}_{!j} next next endif 'calculate correlation matrix entries matrix(!n,!n) correl !correl_counter = 0 for !i = 1 to !n - !correl_counter for !j = 1 to !n if !i = !j then correl(!i,!j) = 1 Else correl(!i,!j) = covf_{!i}_{!j} / ( @sqrt(garchf_{!i})*@sqrt(garchf_{!j})) correl(!j,!i) = correl(!i,!j) endif next !correl_counter = !correl_counter + 1 next
Here the control variable !n stands for the number of imported series and !coeff_counter ranges from the first relevant parameter to the last. As the standard coefficient vector only contains 750 elements one has to create another one with at least 4*(!n + 0.5*(!n^2 - !n) elements for this BEKK using TARCH model.
The code provides a one step ahead forecast conditional on today's information and therefore stands in contrast to the above suggested method under the link: viewtopic.php?f=4&t=346#p9161
Additionally, it can be used for large scale matrices where the number of series can vary.
