NUMERICAL SIMULATION
Posted: Mon May 20, 2013 9:46 am
by thakkar09
I have been working on a model and have put in the equations. I need to know how to solve for the steady states?
Re: NUMERICAL SIMULATION
Posted: Mon May 20, 2013 9:50 am
You might want to read through Jean Louis Brillet's book on modelling in EViews. It covers steady states, I believe.
http://www.eviews.com/StructModel/structmodel.html
Posted: Thu May 23, 2013 1:43 pm
by thakkar09
ok thanks for that. thats some really good info.
Although, I am currently having a problem related to space limit and i still need to further add the scenarios and compare the change in exogenous variables with the baseline. Is their any way i could copy the data and continue with working on my file.!
Also, does any one find this software annoying in the sense that if you open a new work file and put in the same equations as you did in the previous work file, it some how doesn't work! WHY?
it says for e.g.: *g not defined*
Thanks!
Posted: Thu May 23, 2013 2:42 pm
Do you have G defined in the new workfile?
Posted: Thu May 23, 2013 2:43 pm
by thakkar09
yes i know i do have since I have used it before in different work file
Posted: Thu May 23, 2013 2:45 pm
by thakkar09
and currently i am trying to input the below function:
y=demand +g-t+e*k
but it isn't accepting "demand" although the same function i have used previously and this time its accepting g.
It sometime accepts and sometime doesn't. Its random based.
Posted: Thu May 23, 2013 2:46 pm
There is almost certainly nothing random about it. But without knowing exactly what you're doing, and seeing you workfile(s), it is hard to know what you're doing wrong.
Posted: Thu May 23, 2013 3:00 pm
by thakkar09
what do you recommend?
Posted: Thu May 23, 2013 3:01 pm
Explaining exactly what you're doing and providing your workfile.
