AR(1) term in OLS vs. first lag of dependent variable
Posted: Tue Apr 30, 2013 10:09 am
by questionsab
Why does OLS with AR(1) term give different estimation output compared with OLS with first lag of dependent variable. Both regressions have another independent variable.
Re: AR(1) term in OLS vs. first lag of dependent variable
Posted: Tue Apr 30, 2013 10:12 am
Posted: Tue Apr 30, 2013 11:55 am
by EViews Glenn
To expand on Gareth's link, note that the same transformation applies when you have other regressors. The induced restricted lag on the regressors means that there is no longer an equivalence between the two models, even for the non-intercept terms.
Posted: Wed Aug 12, 2015 7:37 am
by clavat
Probably a silly question. But in this case when you no longer have equivalence between the two models, how do you determine whether doing AR(1) or using a first lag is appropriate?
