VECM lag length estimation
Posted: Fri Apr 26, 2013 7:13 am
I would like to estimate a VAR model for four time series. The series are I(1) processes and potentially cointegrated. To confirm I chose the Johansen cointegration test. Since I don't know whether the model should include a deterministic/ stochastic trend or intercept for the cointegrating relationship or the vector autoregression, I opted for summary results. Herein lies the problem: depending on the lag length for the differenced terms in the equation, I get different results for the type of model to choose based on trace/max-eigenvalue. However, I can only test for lag length criteria after actually making the VAR (prior to which I have to decide on intercepts/trends to be included). I need a multivariate test statistic that helps me to decide on model type as well as lag length. I could produce the summary test results for several lag lengths and then select the one with the smallest SBIC or other criterion followed by a lag exclusion test, but I am not confident that this is appropriate. Specifically, I'm not sure what impacts more on the information criteria provided: lag length or model type.
Unfortunately, economic theory is of little help in determining an appropriate lag length/model type a priori. However, it may be assumed that the maximum lag length considered is three (also for practical reasons since larger models would quickly eat up degrees of freedoms due to the number of required coefficients to be estimated. The number of observations per series is n = 120). Any input is greatly appreciated
Regards
Florian
Regards
Florian
