questions on new commands: addarrow and print(pdf)
Liu
Postby Liu » Wed Apr 24, 2013 11:45 am
I am using the two new commands in eviews 8 and I have some questions about them:
For addarrow command, once I place an arrow on the chart, if I move it around and find an ideal place for it, how can I know the coordinate of it?
For graph.save(t=pdf), I noticed that the saved PDF chart lost our template settings for charting (eg., the x axis line is thinner than stipulated in the chart template.).
Is there a way I can print pdf chart and still preserve the template setting?
Thank you.
Re: questions on new commands: addarrow and print(pdf)
Postby EViews Gareth » Wed Apr 24, 2013 11:57 am
Unfortunately you cannot find the location.
Could you provide an example of the pdf printing problem?
Liu
Postby Liu » Thu Apr 25, 2013 7:59 am
Hi Gareth, Please take a look at the two files. One is by a software,(use print command instead of save command)
The pdfeviews.pdf is the one created by save(t=pdf). The problem is that in this file, the x axis is thinner and the letters are more scattered.
pdfeviews.pdf
(72.56 KiB) Downloaded 374 times
biopdf.pdf
(20.97 KiB) Downloaded 412 times
Postby EViews Jason » Thu Apr 25, 2013 8:17 am
Hi Liu,
1) Try turning off label kerning. Go to options->graphics defaults, select Exporting in the tree and then select 'Keep label as a single block of text ....'
2) For the X-axis thin line issue, I will need your workfile. Please send it to support@eviews.com
