Poisson Regression: Z-Statistic, LR Test, and Overdispersion
Posted: Sat May 02, 2009 5:08 pm
Hi all,
I have come across a few problems while estimating a Poisson regression model. I have chosen the simplest Poisson method in eviews, with Huber-White robust standard errors.
1)
While checking for the significance of a binary regressor (gender dummy), the z-statistic and the associated p-value suggest that the coefficient is insignificant. On the other hand, a Likelihood Redundant Variable Test with a single restriction, gender (i.e., under the null, the coefficient on gender is zero), suggests that the coefficient is now significant.
Questions: Which of these is an appropriate result? Is this anomaly a relic of the fact that the two tests are governed by different distributions under the null, or is the Eviews method of executing the Likelihood Redundant Variable test simply not valid for a Poisson regression? This might be of some help: A friend suggested that Eviews might not be calculating consistent estimates for the standard errors for the Z-statistic, or that the LR test is not robust to misspecification.
2)
The standard Poisson regression assumes that the conditional population mean of the dependent variable is equal to its conditional variance. If, on the other hand, we were to relax this assumption along the lines of Generalised Linear Models (GLM), so that the conditional variance is now proportional to (rather than equal to) the conditional mean [a case of over-dispersion], the standard errors of the "equality" model must now be multiplied by the same factor of proportionality to arrive at the standard errors in our new model.
Questions: Is the simplest Poisson regression option in Eviews assuming equality of the conditional mean and conditional variance, or proportionality (as in GLM assumption)? If the former is true, do I need to manually inflate my standard errors in case of over-dispersion, or does Eviews do it automatically? Lastly, do these conclusions change if I use the Huber-White rubust standard errors?
Many thanks.
T
1)
2)
Many thanks.
T
