COM Automation - Get an Alpha series
SVeitch
Postby SVeitch » Tue Apr 09, 2013 7:56 am
All,
I'm trying to write a short code to put out some data, with dates and titles out of EViews and on to and excel spread sheet. But i seem to hav hit a weird issue with the dates, instead of putting a single date into each cell. Each cell ends will a series of dates, starting with the correct date, and then running to the last observation in the file.
The VBA code is
Scommand = "Alpha ZZ_temp = @STRDATE(" & Chr(34) & " DD/MM/YYYY " & Chr(34) & " ) "
app.Run (Scommand)
Dates = app.Get("ZZ_temp")
rows = UBound(Dates, 1) - LBound(Dates, 1) + 1
WST_TV.Range(WST_TV.Cells(4, 1), WST_TV.Cells(3 + rows, 1)) = Dates
What am i doing wrong? I can look at ZZ_Temp and it looks like what I need, but it doesn't seem to be pulling through to excel correctly.
Is there a better way to pull dates out? It feels like i've missed a trick somewhere.
I'm currently using Eviews V7.2
Kind Regards
Sam
Re: COM Automation - Get an Alpha series
Postby EViews Gareth » Tue Apr 09, 2013 8:13 am
Unfortunately our resident COM expert, Steve, is on vacation this week. Might take a while to get an answer :(
SVeitch
Postby SVeitch » Tue Apr 09, 2013 8:54 am
OK, No worries.
Postby EViews Steve » Mon Apr 15, 2013 8:04 am
In the last line of your VBA code, make it say:
WST_TV.Range(WST_TV.Cells(4, 1), WST_TV.Cells(3 + rows, 1)).Value = Dates
SVeitch
Postby SVeitch » Mon Apr 15, 2013 9:56 am
Sorry, but i still get the same issue.
Postby EViews Steve » Mon Apr 15, 2013 3:25 pm
Ok, I was able to confirm this is a bug. I'll let you know when we have a fix for this...
Postby EViews Steve » Tue Apr 16, 2013 9:03 am
This bug has been fixed and will be in the next patch. Not sure when the patch is being released but it should be soon.
Postby EViews Steve » Tue Apr 16, 2013 4:07 pm
Ok, patch for this bug has been built and released. Look for Build Date of: April 16, 2013.
