Parameter Estimation
papu
Postby papu » Wed Apr 29, 2009 11:04 pm
How to estimate the parameters in Eviews with restrictions on the parameters across the equations. The restrictions are of the form a1/b1=a2/b2 for a system consisting of 2 equations of the form:
y=a1*x1+a2*x2+k1 and z=b1*x1+b2*x2+k2
We know what the series y, z, x1, and x2 are.
trubador
Did you use forum search?
Re: Parameter Estimation
Postby trubador » Thu Apr 30, 2009 1:23 am
'define the coefficent vectors and the fixed ratio (a1/b1=a2/b2=r) coef(2) a coef(2) b coef(1) r 'first estimate one of the equations via least squares and save the coefficents equation olsy.ls y = a(1)*x1 + a(2)*x2 !a1=olsy.@coefs(1) !a2=olsy.@coefs(2) 'estimate remaining equation with respect to previously saved coefficents to find r value equation olsz.ls z = r(1)*!a1*x1 + r(1)*!a2*x2 'if E(z) = r*E(y), then you can also estimate r ratio via equation olsr.ls z = r(1)*y 'the paramaters we have just estimated are not exact but close to their real values 'therefore we should jointly estimate the paramaters for actual results. logl joint joint.append @logl ols joint.append res1 = y - a(1)*x1 - a(2)*x2 joint.append res2 = z - r(1)*a(1)*x1 - r(1)*a(2)*x2 joint.append ols =-(res1^2 + res2^2) 'estimation will use our previous ols estimations as starting values joint.ml(showopts, m=1000, c=1e-7) show joint.output 'you can now easily calculate b coefficients b(1) = r(1)*a(1) b(2) = r(1)*a(2) 'you should also try beginning with other equation first and repeat the steps above for b coefficents. 'The results should be nearly identical.
Postby startz » Thu Apr 30, 2009 4:57 am
Use a System with the equations
y=a1*x1+a2*x2+k1
z=b1*x1+(a2*b1/a1)*x2+k2
trubador
Postby trubador » Thu Apr 30, 2009 1:39 pm
Startz' answer is definitely more clean and spare compared to my unnecessarily circuitous solution. It is indeed the most usual way of doing such an estimation I might add. Since the model now becomes nonlinear in its coefficients, it would be wise to preset the value of a1 coefficient to 1 in order to avoid missing value problem for the sake of estimation process.
