BEKK starting values
Posted: Wed Mar 20, 2013 11:38 am
I want to estimate a VAR - BEKK model with two variables and I am confused on the starting values I should use. I see that eviews uses the starting values from an OLS estimation for the mean equation, although I cannot understand what values does it use for the variance equation.
I also tried to use as starting values the estimates from the two univariate GARCH models (for the two variables). Of course, in this case the variance may be nonstationary and the starting value for the BEKK be greater than 1. Is this possible?
I have also seen some other values like 0.01 or 0.5 in some codes.
Are there "correct starting values"? Because in some cases my results change. How can I be sure that I have the correct ones and that I have a global maximum?
Thank you in advance.
